October 18, 2011, 04:58 |
Questions
Rep Power: 17 |
Hello Guys,
I am trying to model droplet entrainment by gas from water film and the deposition of this droplets too. My question is how to model the drag between water droplet and water film. I am applying the three- fluid model approach and using CFX. I found only stuff dealing with droplet interaction time and turbulent effects which are difficult to implement in to this commercial code. Reentrainment (deposition) plays too a very important role: at this moment Entrainment is well solved but because my droplet s becoming bigger they move under the water film. thx Rebecca |
October 18, 2011, 06:16 |
Rep Power: 143 |
Can you show an image of what you are trying to do? I do not understand yet.
October 18, 2011, 07:53 |
Rep Power: 17 |
I am trying to model the onset of droplet entrainment in stratified wavy counter current flow.
Droplet deposition on the water film should be taken in to account. I am defining: Air (continuous), Water (continuous) Water-Droplets (disperse)... If my droplets become bigger or if i have a big amount of them they fall down and go under the water film (Several trial to increase physically the Deposition rate don't lead to better modeling) I am doubting, if its due to the euler-euler approach because Water-Film phase as well as droplet-phase have the same density... Thx Rebecca |
October 18, 2011, 17:01 |
#4 | |
Rep Power: 143 |
October 19, 2011, 02:21 |
Rep Power: 17 |
In the Euler-Euler Approach i should define that drag coefficient between the phases even though the droplet merge to the water film. My problem again is i cannot model that merging (deposition ) phenomena very good. Still have droplets which tend to flow under the water film..
Jessica |
October 19, 2011, 06:47 |
Rep Power: 143 |
Oh I see, the drops and the continuous bit are different phases.
Not sure how you would do this, it is a tricky model. Just a thought - can you use particle tracking rather than the dispersed eularian phase? |
October 19, 2011, 07:28 |
Rep Power: 17 |
Droplets are produced in the domain and are not introduced from a nozzle or something.. that s particle tracking is not welcome.... i thought about defining a relative density of the droplets (assuming that they have a middle density) in order to keep that merging problem out (e.g defining an artificial buoyancy force between the water phase and the droplet phase).
Jessica |
October 19, 2011, 17:36 |
Rep Power: 143 |
You can produce particles as needed here, you don't need nozzles or inlets.
But whether you do it by eularian or lagrangian approach you are going to have to do some development work to get it working. There is no simple approach to my knowledge. |
October 20, 2011, 09:07 |
#9 |
Wow I see it is a very complex simulation.
Are you using the Euler-Euler model (particle) model? I think you might Use the MUSIG model, since you can work with different particles and diameter, and couple them via differente terms.!! |
possible interview questions | atturh | Main CFD Forum | 1 | February 21, 2012 08:53 |
Questions for a species transport problems (snapshots attached) | aleisia | FLUENT | 2 | October 9, 2011 04:40 |
LES basic and simple questions. | dshawul | Main CFD Forum | 0 | October 4, 2010 10:56 |
NACA0012 Validation Case Questions | ozzythewise | Main CFD Forum | 3 | August 3, 2010 14:39 |
Fluent FAQ Started - Fill it With Questions | Jonas Larsson | FLUENT | 0 | September 12, 2005 10:41 |
