Pressure distribution on flapping wing in fluid ANSYS
I am modelling a rigid thin wing flapping in fluid. I have to determine the resulting pressure distribution around the wing.Since i am just a beginner i want an ansys tutorial on such FSI problem. |
Well, did you consider the tutorials that came with CFX?
"Chapter 23: Oscillating plate with two-way fluid structure interaction" is a good start. |
Yes i have seen tutorial23. I wanted to know the steps to create rigid plate hinged at one end which is oscillating with given angular velocity about that hinge in a static fluid medium.
Thank you Lance for the help. I saw Tutorial22 but i wanted to know how can i generate my own ".out" and "expression.ccl" files for my simulation. Can you suggest some steps or tutorial for this?
