Pressure, mass or velocity boundary condition? |
October 21, 2019, 11:15 |
Abdullah Arslan
Rep Power: 7 |
Good day,
I have inlet condition Tin 793K, Pin 1 atm, Vin 0.1 m/s and inlet size is 3.1X1mm. The mixture is multi-component and its density is 227g/m3. Corresponding mass flow rate is 7.0565E-8 kg/m3. For both velocity and mass flow rate inlet (Min) conditions, velocity profile is same with <5% error. But pressure is around 1 Pa in CFX post. Why cannot I get ~ 1atm pressure? P.S Absolute pressure is set 1 atm (it is just reference) and in 'material' tab, reference temperature and pressure are STP (also just reference as CFX theory guide). |
October 21, 2019, 12:20 |
Rep Power: 32 |
It seems you are looking for absolute pressure, correct?
What variable are you looking at in CFD-Post ? Pressure, or Absolute Pressure? Not certain what you meant by setting Absolute Pressure to 1 atm, there is no panel to set Absolute Pressure anywhere. Did you mean to set the domain-based Reference Pressure to 1 atm? |
October 22, 2019, 05:35 |
#3 | |
Abdullah Arslan
Rep Power: 7 |
I am looking for pressure (to be around 1 atm but getting 1-2 Pa just) Yes, there is none and yes I meant domain-based reference pressure. So what is pressure in CFX-post? gauge pressure? |
October 22, 2019, 06:16 |
Gert-Jan
Rep Power: 27 |
The variable Pressure in Post is the deviation from your Reference Pressure.
If your reference pressure is 1 atm, and your Pressure says 1 Pa, then this means that the absolute Pressure is 1atm + 1 Pa |
October 22, 2019, 06:36 |
#5 | |
Abdullah Arslan
Rep Power: 7 |
My dilemma is: I am using ideal gas species at STP. So solution should give at least closer to that value. Or that is gauge pressure? However, at inlet using velocity and not pressure. |
October 22, 2019, 07:31 |
Gert-Jan
Rep Power: 27 |
Static Pressure can be considered as Gauge Pressure, provided you have a reference pressure of 1 atm
You mentioned: "My dilemma is: I am using ideal gas species at STP. So solution should give at least closer to that value." Closer to what value? To Standard Temperature and Pressure? No. If you have a reference pressure of 1 atm, then the variable Pressure will be Static Pressure, relative to reference Pressure. You can get the variable Pressure to be close to STP (1 atm), but then you need to set the reference pressure to vacuum = 0Pa. This is also possible. Results won't change, it is just an off set. |
October 22, 2019, 07:54 |
#7 | |
Abdullah Arslan
Rep Power: 7 |
I will try 0 Reference pressure but tried before and simulation didn't start. |
October 22, 2019, 07:58 |
Gert-Jan
Rep Power: 27 |
In principle, Opaque already pointed you in the right direction. The STP that you are looking for is in the variable "Absolute Pressure" = static pressure + reference Pressure
cfx, pressure boundary |
Display Modes | |
Radiation in semi-transparent media with surface-to-surface model? | mpeppels | CFX | 11 | August 22, 2019 07:30 |
Wrong flow in ratating domain problem | Sanyo | CFX | 17 | August 15, 2015 06:20 |
Boundary Condition for pressure and velocity | mecman | OpenFOAM Pre-Processing | 1 | May 7, 2014 16:51 |
Convective Heat Transfer - Heat Exchanger | Mark | CFX | 6 | November 15, 2004 15:55 |
what the result is negatif pressure at inlet | chong chee nan | FLUENT | 0 | December 29, 2001 05:13 |
