CFX solver problem
Hi all
CFX solver does not work after modelling,meshing and setting a CFX analysis system in Ansys workbanch,it apears to me this error message: "Ccl2flow.exe a cessé de fonctioner" and a win7 error message : "Return value C0000005 >FFFF in parse_rv, treating as not-run" what can I do? |
the same problem
I'm having exatly the same problem. Does can somebody help?
thanks! |
same problem for me
I also have the same issue. Does anyone know what could be the reason? Could it be a license issue?
Thanks in advance, P. |
problem solved
Hi all,
The problem is solved. At least for me it was an interface issue. The contacts had been supressed in meshing, so I had to generate all the interfaces manually. The automatic generation of interfaces was disabled. I had a domain of two solid bodies in contact. By mistake I did not put an interface between the two solid bodies of the same domain and it was not running. After having an interface there, all is fine. P. |
Where do I do this you say?
thank you |
