Propeller cavitation with non condensable gas(first constant property then ideal gas)
Old   February 9, 2015, 04:47
Default Propeller cavitation with non condensable gas(first constant property then ideal gas)
Behrooz Jamshidi
CFD-fellow is on a distinguished road
Hi
Im modeling cavitation on a propeller with a constant volume fraction of air.After a procedure I got converged solution with reasonable results.
Now when I change air to ideal gas (with isothermal heat transfer) or define an expression for variable density with the previous run as initial value, I get overflow error on the first time step.
B.C:velocity inlet and opening with static pressure.
tstep=0.0001
Ive also decreased time step to 10e-9 which didnt help.
Decreasing relaxation factors caused overflow happen later(on 6th tstep)
Any idea?
CFD-fellow is offline   Reply With Quote
Old   February 9, 2015, 05:23
I have attempted a similar simulation previously and never got it to work either. I never looked into it very hard, but you can expect to have a hard time getting this to converge (as you have found). I can only recommend trying some of the solver expert parameters and other solver settings and see if they help, otherwise contact ANSYS and see if they can help you.
Calculation of the Governing Equations Mihail CFX 7 September 7, 2014 06:27
Non condensable gas mas fraction for CAVITATION Xa Main CFD Forum 0 April 2, 2008 11:28
Two-Phase Buoyant Flow Issue Miguel Baritto CFX 4 August 31, 2006 12:02
question about ideal gas thermal flow yong Main CFD Forum 0 January 6, 2006 23:58
Gas pressure question Dan Moskal Main CFD Forum 0 October 24, 2002 22:02
