Error (2 isolated fluid regions) with an englobing domain
Old   January 11, 2012, 15:06
Default Error (2 isolated fluid regions) with an englobing domain
jean-françois jerier
syens is on a distinguished road
I performed a simple simulation (see the attached file), where a part with two holes is included in a englobing domain. The two half-circles at the base of the englobing domain allow to insufflate and extract the fluid in the domain. When I use the englobing domain, I have this error:
2 isolated fluid regions were found in domain Default Domain
If the isolated regions do not have the pressure level set either
by the boundary conditions or using a reference pressure equation,
you may encounter severe robustness problems.
This situation may have arisen because a domain interface was not
properly defined during problem setup. Please carefully check
the setup.
That's strange because I am pretty sure all surfaces are defined like walls, In or Out. I only used proximity and inflation options to generate the mesh.
Have you already observed this error with the englobing domain ?
How can I solve this error ?
Thank for your help
Best regards
JF
syens is offline   Reply With Quote
Old   January 11, 2012, 15:33
Edmund Singer P.E.
singer1812 is on a distinguished road
Set up domain interfaces.
singer1812 is offline   Reply With Quote
Old   January 12, 2012, 10:55
Hi Singer1812,
Thank you for your reply !!!
Best Regards
Wind turbine simulation Saturn CFX 58 July 3, 2020 01:13
Interface between fluid domain and porous domain windhair CFX 6 May 10, 2018 14:26
Kite in centre of Fluid Domain Rich FLUENT 0 March 4, 2005 10:49
block geometry inside fluid domain jeff Main CFD Forum 18 April 12, 2004 11:37
Terrible Mistake In Fluid Dynamics History Abhi Main CFD Forum 12 July 8, 2002 09:11
