Home > Forums > CFX
Export monitor point to file during the run
Old   November 18, 2011, 10:12
Default Export monitor point to file during the run
Matjaz Fleisinger
Matjaz is on a distinguished road
does anybody know if it is possible to export user monitor points to a txt file during the run?
I have a transient MFR simulation, and would like to write values for each time step to an extra txt file (not binary) during the simulation. I belive it should be possible, because it can be monitored in a graph under user points tab, i just don't know how.
Thanks in advance,
Matjaz
Matjaz is offline   Reply With Quote
Old   November 19, 2011, 06:12
ghorrocks is a jewel in the roughghorrocks is a jewel in the roughghorrocks is a jewel in the rough
It already exists in the file, I think called "mon" in the CFX temp directory where the simulation is running. This file is erased when the run completes and has to be read from the res file with cfx5mondata or something like that.
Old   June 13, 2012, 18:07
Saima
Saima is on a distinguished road
Hello Guys,
I want to do the smae thing but instead of user define wants to know the U momentum and mass residual.
I have found command:
"C:\Program Files\ANSYS Inc\v130\CFX\bin\cfx5mondata" -res R67_150k_001.res-varlist "RESIDUAL, RMS, U-Mom; RESIDUAL, RMS, V-Mom" >variables.csv
But iot is giving me follwoing error:
Exporter error:
data::notFound: MonitorDataExporter:utputData - Requested variable(s) not found:
An error has occurred in cfx5mondata:
C:\Program Files\ANSYS Inc\v130\CFX\bin\winnt-amd64\MonitorDataExporter.exe
could not be started, or exited with return code 255: .
Kindly let me know the right way to get all residuals.
Regards,
Best Redards,
Saima
Saima is offline   Reply With Quote
Old   June 16, 2012, 03:33
Brad Fowler
Bfowler is on a distinguished road
Do you just want to extract the values of the residuals (maybe monitor points) at each time step (for post processing in Excel or something similar)? Don't worry about those commands, just right click in the monitor window of the solver and select 'Export...'. Gives you a .csv file for you to do what you wish.
Hope I understood the question properly...
Bfowler is offline   Reply With Quote
Thread Tools
Trackbacks are On
GroovyBC the dynamic cousin of funkySetFields that lives on the suburb of the mesh gschaider OpenFOAM 300 October 29, 2014 19:00
ParaView Compilation jakaranda OpenFOAM Installation 3 October 27, 2008 12:46
DecomposePar links against liblamso0 with OpenMPI jens_klostermann OpenFOAM Bugs 11 June 28, 2007 17:51
Results saving in CFD hawk Main CFD Forum 16 July 21, 2005 20:51
error while compiling the USER Sub routine CFD user CFX 3 November 25, 2002 16:16
