[Sponsors] | |||||
Rep Power: 4 ![]() |
Hello everyone.
I simulate generator thermal behavior with the fan on the outlet side of the fan. But this fan contains many elements which increases computational effort during solving. My question is: Is it possible to replace the fan geometry with its characteristic (airflow vs. pressure drop)?? I heard that it is possible in Fluent but I don't know if it works in CFX. Any reply will help. Thanks a lot. |
Rep Power: 60 ![]() ![]() ![]() |
Yes, use a momentum source and link the source term to an equation describing the fan characteristic curve.
Thanks a lot. Just another question on which domain should I put it?? I have several domains that define generator and I would need to know where to define this equation. Is it on inlet domain??
You can put sources on boundaries, or define sub-domains and apply it to volumes. Whatever is most appropriate in your case.
thanks a lot. I still have some issues concerning expressions. Is there any tutorial on that?
Several of the tutorials use CEL expressions. I am not in my usual office today so cannot list them for you but I know the free surface flow over a bump one uses it and so do several others.
ok I'll find them. thank you again glenn
| Thread Tools | |
| Display Modes | |
| Thread | Thread Starter | Forum | Replies | Last Post |
| Simulation of Axial Fan Flow using A Momentum Source Subdomain | Liam | CFX | 26 | April 23, 2013 16:37 |
| Jet fan and Tunnel simulation | ahlo7 | CFX | 7 | March 7, 2012 10:25 |
| Modeling a Fan by the Multiple reference frame (MRF) method in CFX. | saisanthoshm88 | CFX | 7 | February 14, 2011 04:52 |
| Proper BCs for internal fan | serezhkin | CFX | 3 | July 28, 2010 10:04 |
| Propeller Fan Curve Simulation | Teng_YJ | FLUENT | 2 | February 16, 2009 19:37 |
