December 6, 2011, 05:13 |
Gas flowing into a complex structure
jean-françois jerier
Rep Power: 14 |
Hi all,
I don’t have experiences with CFX, and I would like to know if this software can solve my problem. I read a bit the tutorial and I found a similar problem to mine (Catalytic converter with honeycomb). My question: Is it possible to simulate with CFX, the gas (Nitrogen) flowing into the Catalitic converter by modelling the honeycomb structure. What are the major difficulties: the meshing, the cost time, the model, ... All suggestions are welcome Thank you in advance for your help. Best regards Syens |
December 6, 2011, 05:25 |
Rep Power: 14 |
Yes, it is possible, as you have already discovered.
You will have to invest quite a bit of time to get a good solution. I am not an expert with your field, but if you can use specialised software, you should achieve results quicker. CFX and most CFD software cover all fluid flow, hence quite broad, so the onus is on the user to set up the problem. The advantage is that one can do much more using CFD software, with the possibility of greater accuracy. |
mass flow in is not equal to mass flow out | saii | CFX | 12 | March 19, 2018 05:21 |
Constant velocity of the material | Sas | CFX | 15 | July 13, 2010 08:56 |
Two-Phase Buoyant Flow Issue | Miguel Baritto | CFX | 4 | August 31, 2006 12:02 |
quantity of gas flowing through a pipe | Prem Siril | Main CFD Forum | 0 | June 7, 2004 05:36 |
Gas pressure question | Dan Moskal | Main CFD Forum | 0 | October 24, 2002 22:02 |
