-   -   CFX13 Post Periodic interface (http://www.cfd-online.com/Forums/cfx/95158-cfx13-post-periodic-interface.html)
EtaEta December 7, 2011 19:13
I am simulating a axial compressor rotor. I used my mesh in CFX11 and CFX 13. I waited until mass is converged for both cases.
When I used CFX 11, upper periodic side and lower periodic side have same Velocity v. But, for the case with CFX 13, upper periodic side and lower periodic side have slightly different Velocity v. Especially near blade tip.
What am I doing wrong?
ghorrocks December 8, 2011 02:24
Can you post an image? And CCL would help.
EtaEta December 8, 2011 15:18
Here are CCL & image
1 Attachment(s)
I attached an axial cut of passage. It shows an unexplainable shift.
Thank you
Here is the CCL:
PHP Code:
CFX Command Language for Run                    |
LIBRARY:
MATERIALAir Ideal Gas
     Material Description
Air Ideal Gas (constant Cp)
Material Group Air DataCalorically Perfect Ideal Gases
     Option
Pure Substance
     Thermodynamic State
Gas
     PROPERTIES
Option General Material
       EQUATION OF STATE
Molar Mass 28.96 [kg kmol^-1]
Option Ideal Gas
       END
       SPECIFIC HEAT CAPACITY
Option Value
         Specific Heat Capacity
1.0044E+03 [J kg^-1 K^-1]
Specific Heat Type Constant Pressure
       END
       REFERENCE STATE
Option Specified Point
         Reference Pressure
[atm]
Reference Specific Enthalpy 0. [J/kg]
Reference Specific Entropy 0. [J/kg/K]
Reference Temperature 25 [C]
END
       DYNAMIC VISCOSITY
Dynamic Viscosity 1.831E-05 [kg m^-1 s^-1]
Option Value
       END
       THERMAL CONDUCTIVITY
Option Value
         Thermal Conductivity
2.61E-2 [W m^-1 K^-1]
END
       ABSORPTION COEFFICIENT
Absorption Coefficient 0.01 [m^-1]
Option Value
       END
       SCATTERING COEFFICIENT
Option Value
         Scattering Coefficient
0.0 [m^-1]
END
       REFRACTIVE INDEX
Option Value
         Refractive Index
1.0 [m m^-1]
END
     END
   END
 END
 FLOW
Flow Analysis 1
   SOLUTION UNITS
Angle Units = [rad]
Length Units = [m]
Mass Units = [kg]
Solid Angle Units = [sr]
Temperature Units = [K]
Time Units = [s]
END
   ANALYSIS TYPE
Option Steady State
     EXTERNAL SOLVER COUPLING
Option None
     END
   END
   DOMAIN
R1
     Coord Frame
Coord 0
     Domain Type
Fluid
     Location
Passage
     BOUNDARY
R1 Blade
       Boundary Type
WALL
       Frame Type
Rotating
       Location
BLADE
       BOUNDARY CONDITIONS
HEAT TRANSFER:
Option Adiabatic
         END
         MASS
AND MOMENTUM:
Option No Slip Wall
         END
         WALL ROUGHNESS
Option Smooth Wall
         END
       END
     END
     BOUNDARY
R1 Hub
       Boundary Type
WALL
       Frame Type
Rotating
       Location
HUB
       BOUNDARY CONDITIONS
HEAT TRANSFER:
Option Adiabatic
         END
         MASS
AND MOMENTUM:
Option No Slip Wall
         END
         WALL ROUGHNESS
Option Smooth Wall
         END
       END
     END
     BOUNDARY
R1 Inlet
       Boundary Type
INLET
       Frame Type
Stationary
       Location
INFLOW
       BOUNDARY CONDITIONS
FLOW DIRECTION:
Option Cylindrical Components
           Unit Vector Axial Component
1
           Unit Vector Theta Component
0
           Unit Vector r Component
0
         END
         FLOW REGIME
Option Subsonic
         END
         HEAT TRANSFER
Option Stationary Frame Total Temperature
483.35 [K]
END
         MASS
AND MOMENTUM:
Option Stationary Frame Total Pressure
           Relative Pressure
195.218 [kPa]
END
         TURBULENCE
Option Medium Intensity and Eddy Viscosity Ratio
         END
       END
     END
     BOUNDARY
R1 Outlet
       Boundary Type
OUTLET
       Frame Type
Stationary
       Location
OUTFLOW
       BOUNDARY CONDITIONS
FLOW REGIME:
Option Subsonic
         END
         MASS
AND MOMENTUM:
Mass Flow Rate 0.10005 [kg s^-1]
Option Mass Flow Rate
         END
       END
     END
     BOUNDARY
R1 Shroud
       Boundary Type
WALL
       Frame Type
Rotating
       Location
SHROUD
       BOUNDARY CONDITIONS
HEAT TRANSFER:
Option Adiabatic
         END
         MASS
AND MOMENTUM:
Option No Slip Wall
           WALL VELOCITY
Option Counter Rotating Wall
           END
         END
         WALL ROUGHNESS
Option Smooth Wall
         END
       END
     END
     BOUNDARY
R1 to R1 Internal Side 1
       Boundary Type
= INTERFACE
Location SHROUD TIP GGI SIDE 1
       BOUNDARY CONDITIONS
HEAT TRANSFER:
Option Conservative Interface Flux
         END
         MASS
AND MOMENTUM:
         END
         TURBULENCE
         END
       END
     END
     BOUNDARY
R1 to R1 Internal Side 2
       Boundary Type
= INTERFACE
Location SHROUD TIP GGI SIDE 2
       BOUNDARY CONDITIONS
HEAT TRANSFER:
         END
         MASS
AND MOMENTUM:
         END
         TURBULENCE
         END
       END
     END
     BOUNDARY
R1 to R1 Periodic 1 Side 1
       Boundary Type
= INTERFACE
Location PER1
       BOUNDARY CONDITIONS
HEAT TRANSFER:
         END
         MASS
AND MOMENTUM:
         END
         TURBULENCE
         END
       END
     END
     BOUNDARY
R1 to R1 Periodic 1 Side 2
       Boundary Type
= INTERFACE
Location PER2
       BOUNDARY CONDITIONS
HEAT TRANSFER:
         END
         MASS
AND MOMENTUM:
         END
         TURBULENCE
         END
       END
     END
     DOMAIN MODELS
BUOYANCY MODEL:
Option Non Buoyant
       END
       DOMAIN MOTION
Alternate Rotation Model true
         Angular Velocity
26286 [rev min^-1]
Option Rotating
         AXIS DEFINITION
Option Coordinate Axis
           Rotation Axis
Coord 0.1
         END
       END
       MESH DEFORMATION
Option None
       END
       REFERENCE PRESSURE
Reference Pressure [atm]
END
     END
     FLUID DEFINITION
Air Ideal Gas
       Material
Air Ideal Gas
       Option
Material Library
       MORPHOLOGY
Option Continuous Fluid
       END
     END
     FLUID MODELS
COMBUSTION MODEL:
Option None
       END
       HEAT TRANSFER MODEL
         Include
Viscous Work Term On
         Option
Total Energy
       END
       THERMAL RADIATION MODEL
Option None
       END
       TURBULENCE MODEL
Option SST
       END
       TURBULENT WALL FUNCTIONS
High Speed Model On
         Option
Automatic
       END
     END
   END
   DOMAIN
INTERFACE: R1 to R1 Internal
     Boundary List1
     Boundary List2
Interface Type Fluid Fluid
INTERFACE MODELS:
Option General Connection
       FRAME CHANGE
Option None
       END
       MASS
AND MOMENTUM:
         MOMENTUM
INTERFACE MODEL:
Option None
         END
       END
       PITCH CHANGE
Option None
       END
     END
     MESH CONNECTION
Option GGI
     END
   END
   DOMAIN
INTERFACE: R1 to R1 Periodic 1
     Boundary List1
     Boundary List2
INTERFACE MODELS:
Option Rotational Periodicity
       AXIS DEFINITION
         Rotation Axis
Coord 0.1
       END
     END
     MESH CONNECTION
Option GGI
     END
   END
   OUTPUT CONTROL
MONITOR OBJECTS:
MONITOR BALANCES:
Option Full
       END
       MONITOR FORCES
Option Full
       END
       MONITOR PARTICLES
Option None
       END
       MONITOR POINT
outletpressure
         Expression Value
ave(Pressure)@R1 Outlet
         Option
Expression
       END
       MONITOR RESIDUALS
Option Full
       END
       MONITOR TOTALS
Option Full
       END
     END
     RESULTS
Extra Output Variables List = Mach Number,Total Pressure,Total \
Pressure in Stn Frame,Total Temperature,Total Temperature in Stn \
Frame,Velocity in Stn Frame,Vorticity,Wall Shear,Temperature,Total \
Enthalpy in Stn Frame,Rotation Velocity
       File Compression Level
= Default
Option Standard
     END
   END
   SOLVER CONTROL
Turbulence Numerics First Order
     ADVECTION SCHEME
Option High Resolution
     END
     CONVERGENCE CONTROL
Length Scale Option Conservative
       Maximum Number of Iterations
500
       Minimum Number of Iterations
1
       Timescale Control
Auto Timescale
       Timescale Factor
1
     END
     CONVERGENCE CRITERIA
Residual Target 0.000001
       Residual Type
MAX
     END
     DYNAMIC MODEL CONTROL
       Global
Dynamic Model Control On
     END
   END
 END
 COMMAND FILE
Version 13.0
   Results Version
13.0
 END
 SIMULATION CONTROL
EXECUTION CONTROL:
EXECUTABLE SELECTION:
Double Precision Off
     END
     INTERPOLATOR STEP CONTROL
Runtime Priority Standard
       MEMORY CONTROL
Memory Allocation Factor 1.0
       END
     END
     PARALLEL HOST LIBRARY
HOST DEFINITIONeTaEta
         Remote Host Name
EtaEta
         Installation Root
C:\Program Files\ANSYS Inc\v%v\CFX
         Host Architecture String
winnt-amd64
       END
     END
     PARTITIONER STEP CONTROL
Multidomain Option Independent Partitioning
       Runtime Priority
Standard
         Use
Large Problem Partitioner Off
       END
       MEMORY CONTROL
       END
       PARTITIONING TYPE
MeTiS Type k-way
         Option
MeTiS
         Partition Size Rule
Automatic
         Partition Weight Factors
0.500000.50000
       END
     END
     RUN DEFINITION
Solver Input File = \
C:\Users\EtaEta\Base\base_v1_m_010005_new_002.res
       Run Mode
Full
     END
     SOLVER STEP CONTROL
       MEMORY CONTROL
       END
       PARALLEL ENVIRONMENT
Number of Processes 2
         Start Method
HP MPI Local Parallel
         Parallel Host
List = eTaEta*2
       END
     END
   END
 END
ghorrocks December 8, 2011 17:23
Can you show what the problem is? It is not clear.
But if you are talking about the interfaces then that is just a post processing rendering thing. The underlying simulation should be the same. View both simulations with the same post processor and it should look the same.
EtaEta December 8, 2011 17:46
If you look to the picture, you can see there is a clear shift in the middle.
Normally, two periodic interfaces should coincide and have same values.
It is a not a interface problem. I think there is a tolerance in the periodic side, whose default value is increased when switching from CFX 11 to CFX 13. :confused:
Thanks
ghorrocks December 8, 2011 17:51
As I said, I suspect it is a post processing issue. Have you compared the two runs on the same post processor? It might be rendered differently between V11 and V13.
EtaEta December 8, 2011 17:57
Yes, I did. CFX 11 run has same velocities at periodic boundary in CFX 13 Post. But still, the run from CFX 13, in CFX 13 Post, shows slightly different velocities. :(
(CFX 11 Post does not accept the runs of CFX 13)
ghorrocks December 8, 2011 18:15
So that proves it, doesn't it? It is a post-processor rendering thing. The simulations are the same.
