Home > Forums > CFX
How to monitor pressure in trasient simulation of a rotating blade?
Old   December 9, 2011, 06:25
Default How to monitor pressure in trasient simulation of a rotating blade?
Jack
ripperjack is on a distinguished road
Hi, guys,
I am doing trasient simulation of a rotating blade. I want to monitor pressure at some location of the blade outlet, the location is statonary in the absolute coordinate and do not rotate during the simulation.
As I know, CFX will assign a vertex according to the specificed monitor location, and the vertex will rotate during the simulatioin. That is not the way I want to monitor. Is there any solution?
Thanks!
ripperjack is offline   Reply With Quote
Old   December 12, 2011, 00:16
D.B
DB
D.B is on a distinguished road
If you are done with the simulation and working in post, define the vertex in post. and extract its value for all time steps. When you do it in such a way it won't rotate in post.
-D.B
D.B is offline   Reply With Quote
Old   December 15, 2011, 10:49
Jack
Thanks for your reply!
I want to perform FFT analysis, so I cant save all the trasient results on my harddisk. It is too large!
Is there any way to extract the vertex value during the CFX solving process?
Old   December 15, 2011, 12:41
Far
Sijal
Far will become famous soon enoughFar will become famous soon enough
Send a message via Skype™ to Far
define it in pre and get data on that point only
Far is offline   Reply With Quote
Old   December 16, 2011, 02:30
Jack
I tried "probe(Pressure)@" expression, however, the probe location must be a monitor point or source point according to CFX manual, which will rotate during the simlation.
Also, I tried to define "export results" in CFX pre, but only a surface can be exported, not a point!
Would you please tell me more specificly how to define the point?
Thank you!
Thread Tools
Trackbacks are On
Laminar flow simulation in rotating domain rahulv CFX 7 July 9, 2014 06:19
Monitor pressure on the rotating blade BalanceChen CFX 18 October 31, 2011 07:12
Fan Blade Simulation. 2D CFD with FLUENT? CFX? aerospain ANSYS 0 December 3, 2010 07:08
wear rate simulation of a blade shotblasting cecep Main CFD Forum 1 December 2, 2010 03:28
modification for rotating cylinder simulation zonexo Main CFD Forum 3 July 21, 2006 14:24
