Volute outlet flow into impeller inlet
Old   December 14, 2010, 19:33
Lightbulb Volute outlet flow into impeller inlet
Anthony
Anthony_impeller is on a distinguished road
Hello all,
Firstly this forum is an excellent resource and all that contribute should be recognised as generous and extremely helpful.
I am investigating basic fluid flow through a two stage turbine model. I have modelled up both a nozzle and volute to direct flow radially towards an outlet. (Picture 1)
I am having trouble modelling an impeller at this outlet. I would like to either include the impeller in a single CFX simulation or feed the volute outlet data to a seperate CFX simulation.
When adding the impeller mesh to the CFXpre software I recieve a single passage mesh. (Picture 2)
I would like to have the entire velocity (pressure and such) distribution of the volute acting on the impeller blades. How can I simulate this?
I am not sure whether to operate CFXpre in turbo mode or general mode and what boundaries (and connections) to establish.
Any help or references to specific resources would be very much appreciated. If more information or files are required to answer please let me know and I will upload them with haste.
Kind Regards,
Anthony.
Anthony_impeller is offline   Reply With Quote
Old   December 30, 2010, 08:34
BalanceChen is on a distinguished road
I haven't done the turbine computation, but i recently am doing some simular computation on a compressor. Do you use the Pre Turbo mode? In this mode, you can specify the passages you want to model. For the volute, just use the stator component when import the mesh, no "blade" or "hub" need to be set, the default boudary should be wall, so it should have no problem in the simulation.
Hope it helps,
Best wishes,
BalanceChen
BalanceChen is offline   Reply With Quote
Old   December 13, 2011, 02:32
Default how to simulate volute -rotor for radial turbine
nitheshkumble is on a distinguished road
hi,
I am investigating basic fluid flow through radial turbine model. I have modelled up both a stator and volute to direct flow radially towards an outlet.
I would like to simulate volute casing and rotor simulation interaction using CFx.
1. firstly,I want simulate only volute casing ,for that how to give BC,interface in CFX.
2.ansys mesh is used for meshing.
3.in cfx pre ,while importing whether it is necessary that we have to import only in .gtm or .cfx format.
with regards,
Nithesh KG
nitheshkumble is offline   Reply With Quote
Old   December 13, 2011, 02:45
only one sector was meshed ,hence you will get only that sector in the CFX pre.
To get entire blade meshing and simulation you have to follow the following method,
right click on mesh in CFX pre (tree),you will get mesh transformation, give angle for transformation. (for an example suppose rotor blade is 15 then 360/15=24 degree).
Old   December 13, 2011, 16:17
Anthony,
Have you looked at the various stage interface options such as frozen rotor? Look these up in the documentation and have a look at the tutorials on rotating machinery.
distribution, impeller, turbine, volute
Pulsatile pressure inlet with pressure outlet a.lynchy FLUENT 3 March 23, 2012 13:45
Pulsating flow with non-reflective inlet boundary cc1000 CFX 6 April 27, 2009 08:10
Mass Flow Inlet Pravir Kumar Rai FLUENT 0 February 19, 2003 14:03
Mass Flow Inlet Pravir Kumar Rai FLUENT 0 February 17, 2003 19:23
what the result is negatif pressure at inlet chong chee nan FLUENT 0 December 29, 2001 05:13
