Error in CFX (BIG model)
Old   March 17, 2008, 13:26
Default Error in CFX (BIG model)
Vitaliy
I have many boundary conditions and expressions in my model. And at solving, I have such error:
Details of error:- ---------------- Error detected by routine NAMLST CLIST = CMONOBJ_PATH CVALUE = /FLOW/SOLUTION/LATEST/ZN2/TOTALS/BCP1445/ENERGY_SL1 CRESLT = BIG
Current Directory : /FLOW/CONTROL/OUTPUT/MONITOR
+--------------------------------------------------------------------+ | Writing crash recovery file | +--------------------------------------------------------------------+
Details of error:- ---------------- Error detected by routine PEEKCA CDANAM = PTOT_OPT CRESLT = NONE
Current Directory : /FLOW/PHYSICS/ZN1
Help me please!!!
Old   December 21, 2011, 10:43
MJ
mehshan.javaid is on a distinguished road
Hi. I am having similar issue. were you able to solve your problem?
mehshan.javaid is offline   Reply With Quote
Old   December 22, 2011, 13:19
MJ
I am trying to work my way out of it. Apparently, I can see that CFX is running out of memory. Try to divide the job into 2 or 3 parts and then run each one separately and then combine them one by one. At this point, remove any monitor points and keep it simple.
Will let you know when I solve this issue 100 %
Old   December 22, 2011, 15:53
Monitor points should not make any difference, although the error message suggests it might.
A preferred solution is to run the simulation on a cluster. That is the easiest way to keep the memory requirements under control.
importing & solving 2D model of pipe mesh in CFX 12.1(axisymmetric model) m.salemi CFX 7 July 24, 2011 08:20
"Full" buoyancy model in CFX Jade M Main CFD Forum 2 March 18, 2010 12:08
CAD model sliver faces - CFX Mesh - Parasolid? Ianto CFX 3 February 8, 2009 18:32
How to use the competing reaction model in CFX 11 NewCoalman CFX 0 May 5, 2008 03:15
Use of 1 equation turbulence model in CFX 4.3 Niels Deen CFX 0 July 19, 2000 08:50
