December 27, 2011, 06:33 |
weird Cd of CFX result
Rep Power: 14 |
Dear All,
I simulated steady 3D cylinder to compute drag coefficient. I attached two figures - one is grid and another is Pressure coefficient. Boundary condition is like as; Diameter :0.08 m Inlet velocity 2.0 m/s turbulence model : k-e model When I compute Cd using CCL, the value is too low, it is around 0.25. I also check force_x@cylinder, the value of force_x@cylinder is 0.04N. I thought the value of Cd should be around 1.0 but the result is too low. Do you have any idea or comments on this problem? Best Regards, |
December 28, 2011, 04:36 |
anonymous
Rep Power: 14 |
I assume your fluid is air? Then your Reynolds-Nummer is about Re=11000 and your flow is still laminar (but you use a turbulence model). At this Re-Number you also get "vortex-street instabilities", so i think a transient run would catch your drag more accurate. And maybe check the area of your cylinder in z-direction or other parameters of the cd determination. Furthermore your grid seams a little bit coarse to me. Maybe you could create a 2-dimensional model if you not have enough hardware power to run with a fine mesh in 3d. This problem is a well known example in cfd though. You should find a lot of further information on the internet or the common literature. Best Regards Paul |
December 28, 2011, 05:15 |
#3 | |
Rep Power: 14 |
I will do that . |
December 28, 2011, 05:21 |
Rep Power: 143 |
"Why is my simulation inaccurate" has been asked thousands of times, so have a look at the FAQ:
http://www.cfd-online.com/Wiki/Ansys..._inaccurate.3F And yes, your mesh is almost certainly too coarse. If the fluid is air then Re=1e5 is in the transitional region. This is the hardest region to simulate accurately and will require great attention to detail to get accurate results. |
December 28, 2011, 05:22 |
#5 | |
Rep Power: 14 |
Thank you !! Last edited by colopolo; December 28, 2011 at 05:44. |
December 28, 2011, 05:36 |
#6 | |
Rep Power: 143 |
So I have no idea what you comment is referring to. |
December 28, 2011, 05:43 |
#7 | |
Rep Power: 14 |
At this time, I mean I fully agreed your opinion because I finally understood what I was wrong through literature review and your comments. Thanks you for your quick response. |
how to export cfx result to CGNS format | littlelz | CFX | 3 | April 29, 2010 08:15 |
ATTENTION! Reliability problems in CFX 5.7 | Joseph | CFX | 14 | April 20, 2010 15:45 |
Water pump OpenFOAM 15 ANSYS CFX 110 comparation | waynezw0618 | OpenFOAM Running, Solving & CFD | 39 | March 5, 2009 12:57 |
May I import the definition or result files of CFX | Hao | FLUENT | 0 | November 26, 2008 04:12 |
CFX 10's solutions differ from CFX 5.7's | Atit Koonsrisuk | CFX | 4 | July 26, 2006 11:59 |
