CFX withy radiation can not work
Old   January 9, 2012, 04:08
Default CFX withy radiation can not work
sunpeng
baobaochong is on a distinguished road
Hello, everyone
I met a problem when I using the cfx to calculate a 3-D cascade flow conjugate heat transfer problem.
when I only consider the convection and condution, the cfx-solver can work and I can get a result. But when I add the radition, the cfx-solver can not work. The radiation model I used is the Discret transfer model, the spectral model is weigthed sum of gray gases.
The cfx-solver stopped and the .out is as blew:
Radiation Coarsening Information
Domain Name: Coolant Domain
Target coarsening rate = 64
Number of fine grid elements =2473259
Number of radiation elements = 44048
Actual coarsening rate = 56
Domain Name:Hot Gas Domain
Number of fine grid elements =5905449
Number of radiation elements = 114592
Actual coarsening rate = 51
ERROR #001100279 has occurred in subroutine ErrAction.
Stopped in routine SU_SURF_TRI_3
Does anybody know where the problem is and what I should do to get a result.
I hope I can get help here and Thanks a lot.
baobaochong is offline   Reply With Quote
Old   January 9, 2012, 04:47
I would try different coarsening rates. Just a guess, but easy to try.
Old   January 9, 2012, 10:42
stumpy is on a distinguished road
You can try:
1. Make sure you are not using an old version of CFX
2. If you have a thin surface, split the two sides to appear in separate boundary conditions.
stumpy is offline   Reply With Quote
[ICEM] Proper way to name boundaries on 2D model for use in CFX? RossFS ANSYS Meshing & Geometry 4 November 10, 2011 02:38
Thermal Radiation doesn´t work?! ehrenwirth CFX 14 June 4, 2009 18:54
CFX 5.5.1 for 2D work blair CFX 9 May 20, 2003 10:29
Radiation CFX 5.5 Mate CFX 3 March 21, 2003 01:44
North American CFX User Conference Chris Reeves CFX 0 October 4, 2001 08:29
