Mistakes in CFX-SOLVER
Old   May 15, 2012, 06:49
Default Mistakes in CFX-SOLVER
Stefan
shanxuewenjdx is on a distinguished road
| An error has occurred in cfx5solve: |
| The ANSYS CFX solver could not be started, or exited with return |
| code 255: . No results file has been created. |
End of solution stage.
| The following transient and backup files written by the ANSYS CFX |
| solver have been saved in the directory |
| E:\GEAR_CFX3_groove_0.03\gearpumpgap002groove_005: |
| 0.trn |
| The following user files have been saved in the directory |
| mon |
This run of the ANSYS CFX Solver has finished.
What can I do to?
shanxuewenjdx is offline   Reply With Quote
Old   May 15, 2012, 07:45
Either CFX is not set up correctly on your machine, or your simulation has a bug in it which prevents it from starting.
Can you run other simulations (such as the tutorial examples or benchmark.def)? Can you run parallel simulations?
Old   May 15, 2012, 08:16
Stefan
Thank you.I have done some related examples successfully before. But as the model is more complicated, the simulation is harder to run successully. Does this have something to do with the computer memory?
Old   May 15, 2012, 19:25
If it ran out of memory it would give an error message saying so. Looks like there is a problem with your simulation setup.
Old   May 21, 2012, 09:07
Default Basic question-CFX
Stefan
Is there any example or material that is related with "Domain interface"?
Thank you
Old   May 21, 2012, 18:31
Do the CFX tutorials examples which use a GGI interface, there are a few of them.
cfx
Error message CFX Solver Fatnes CFX 25 July 3, 2015 10:32
CFX SOLVER error !!! mehrdadeng CFX 3 November 23, 2009 16:42
mach number and CFX 11.0 solver turbinesv CFX 5 January 5, 2009 05:43
CFX Solver to run 10 files sequentially Raj CFX 8 October 29, 2008 22:20
problem in CFX solver about isolated volumes Yuan CFX 2 August 16, 2004 22:54
