pressure drop
Old   January 31, 2012, 05:49
Default pressure drop
albert
pato is on a distinguished road
Hi, i´m sorry to ask again but i n would like to ask you what you think the best solution for my problem is.
I just modelled a perforated plate(1cm thick), obtaining the velocity profile along the plate.
Considering that now i have to get the same results but replacing the 1cm plate for a porous media, what boundary conditions would you change in order to get the same velocity profile??
i´m trying to write a pressure drop throug the interface of the porous media, but don´t really know what equation should i use, finding different information depending on the website i search.
could anybody please help me?
pato is offline   Reply With Quote
Old   January 31, 2012, 07:11
Dimeflow is on a distinguished road
Hi Pato,
If you've explicitly modelled your perforated plate, then you could measure the pressure drop across, and divide by the the plate thickness.
This will give you your (-deltaP/deltaX) value which you can assign as a General Momentum Source term.
If the perforations are only in one direction, you can apply a large number in the other two (10^6)
Cheers
EDIT: you'll want to set this up as a subdomain
Dimeflow is offline   Reply With Quote
Old   January 31, 2012, 10:24
albert
yes, the only problem is that the pressure on the perforated plate was not constant.
Old   January 31, 2012, 10:44
but is the pressure drop across it constant?
Old   January 31, 2012, 10:52
albert
no, it is not constant, that is the main problem.
how to obtain an specific velocity profile in the upper part of my porous media. In the simulation with preforated plate i had an irregular drop pressure along the plate, which caused an specific velocity profile. My task is to reach this velocity profile with porous media.
Old   January 31, 2012, 11:44
obvious suggestion, but does the the pressure drop change discretely (ie if the number/size/arrangement of perforations changes discretely). If so you could set various subdomains with individual pressure drops assigned.
Old   January 31, 2012, 11:53
albert
All perforations have the same size, and are placed at the same distance from each oher. nevertheless the drop pressure through the last perforations is much bigger than at the beginning. that is tmay problem, how to modelate this drop pressure.
Old   February 1, 2012, 09:51
albert
do you have any idea how to solve it?? i´d be really grateful if someone could help me. I´m completely stucked and can´t go any further.
Thank you all
Old   February 1, 2012, 11:46
Hi Pato. If estimating the pressure drop properties via loss coefficients is not an option, it seems what you're after doing is defining a pressure drop profile from your explicit model(s) results, and assigning this to your porous model.
There's every chance there's a far easier way to go with this... but one option could be to set up a number of simple test cases with an inlet positioned directly perpendicular to a portion of your perforated plate from original model. Running at different speeds will allow you to measure the varying pressure drop across the medium and build a deltaP v Vel curve, which you can then use to create a function in CFX, which can in turn be referred to in a CEL expression in the Momentum Source/Sink term.
Sound a realistic option?
Has been a while since I've done something like this so will have a quick read tomorrow and post anything that may at all be of help. Like I said, there may be an easier way to go about this.
pressure drop in the pipe mike.mm FLUENT 6 February 7, 2011 10:31
Pipe Flow - Pressure Drop Daniel L FLOW-3D 2 December 10, 2010 04:23
Total and static pressure drop Janakiram Siemens 1 February 8, 2009 01:32
Pressure Drop at entrance of a rotor-stator. Resnick Main CFD Forum 0 November 20, 2007 14:50
Periodic boundaries and pressure drop MatejK CFX 2 July 12, 2005 04:47
