Mapping method in FSI
Old   January 3, 2012, 07:52
Default Mapping method in FSI
Mina
Mina_Shahi is on a distinguished road
Dear Ansys users
i am simulating 2-way FSI with Workbench version 13. i created two models one for fluid flow in CFX and a second for structural vibration. and then linked these two in ANSYS WORKBENCH. in which displacement and pressere exchanged between two modules. But i am wondering that what kind of mapping method Workbench uses for transfering loads . because meshes on both sides of the interface connection are usually not matching.
i created both models and just linked them and every thing between is done by workbench automatically. does anyone know about mapping method using in workbench?
Mina_Shahi is offline   Reply With Quote
Old   January 3, 2012, 16:56
stumpy is on a distinguished road
It's the same as the GGI mapping in CFX. The CFX documentation should say something about that mapping. An important point is that force is conserved.
stumpy is offline   Reply With Quote
Old   January 4, 2012, 03:32
Mina
Thanks for the answer, but in the CFX documentation it is written :
Fluid-Solid interfaces are required at the bounding region between a fluid domain and a solid domain, but are often generated automatically. The mesh on these interfaces must be matching.
when you have both domains in CFX it is possible to have matching mesh but when the fluid part will be solving in CFX and Structure one in the ANSYS multiphyisics (ans both in the workbench package) then it is not always the case and you won't have always matching mesh and usually the mesh in fluid part is much finer.
Let me know what you think,
Old   January 4, 2012, 11:03
In the CFX 13.0 doc see:
// Modeling Guide // 5. Domain Interface Modeling // 5.4. Mesh Connection Options // 5.4.3. GGI (General Grid Interface) Connections
and
// Theory Guide // 3. GGI and MFR Theory
also see the MAPDL doc:
// Coupled-Field Analysis Guide // 3. The ANSYS Multi-field (TM) Solver - MFS Single-Code Coupling // 3.1. The ANSYS Multi-field solver and Solution Algorithm // 3.1.1 Load Transfer
Hope this helps!
Old   January 5, 2012, 05:26
Mina
and
Hope this helps!
Thanks a alot, but one more question when you use workbench you don't know which mapping (global or blucket) it uses .
I just know that there are some folders which workbench makes (while doing FSI) and mapping method perhaps is available somewhere there, but i don't know exactly where, Can you please help me with that?
Old   January 5, 2012, 09:23
In a completed run search for the ANSYS.mf file. This is the final input file to the structural solver. Near the end of this file you'll see a list of commands that start with "MF". You can look in the MAPDL doc for the details of each command. The mapping algorithm is part of the MFLC commands. There'll be two command for each FSI interface - one to map the displacement to CFX (this will use the NONC option) and one to map the force to ANSYS (this will use the CPP method).
Old   January 9, 2012, 06:54
Question
Mina
Many thanks!
1- Is it also possible to change this item like NONC to CPP? OR VICE VERSA
2- in Ansys manuall it is written that :
CPP
Conservative: Uses a local conservative formulation while preserving the density profile (default for total force and wall heat flow). In the conservative formulation, total force (or heat flow) must be transferred across the interface from the CFX field solver to the ANSYS field solver.
Why local conservative and not global??? because in ansys documentation it mentioned that there are two method of interpolating: 1- globally conservative interpolation and 2- profile preserving interpolation .
Global or local conservative????
Old   January 9, 2012, 10:38
I think the doc is wrong. The force transfer is locally and globally conservative.
Old   January 9, 2012, 10:54
Mina
Dear Stumpy
"" globally conservative interpolation " you can find it in ANSYS release 13.0 in the ANSYS Multi-field (TM) solver- MFS- Code coupling : for load transfer
What do you think? You think it is not correct??
Thank you !
Old   January 9, 2012, 11:48
Best to check with ANSYS support.
FSI Problem - Utilizing ALE method to map solutions natern OpenFOAM 1 November 7, 2011 17:00
Structural force in FSI mapping Fluent 12.0 benjamon FLUENT 1 October 24, 2011 10:32
difference in the trimming and mapping method guru STAR-CD 1 April 25, 2011 10:48
[Gmsh] Import gmsh msh to Foam adorean OpenFOAM Meshing & Mesh Conversion 24 April 27, 2005 08:19
Implicit method of FSI cjtune Siemens 0 March 12, 2003 12:07
