Ansys 13---> HP-MPI or Intel-MPI
HI All,
I have installed the ANSYS 13. After the installation, i want to install "MPI for FLUENT Parallel", . I want to know that which MPI should I install, Intle-MPI or HP-MPI??? I read the Anysy Help Manual, but i did not understand my answer. So could anyone please tell me about this question? Plus, for each of HPMPI and Intel_MPI there is an installation instruction , and at the end of each instruction ( for example, HPMPI version) there are two steps that I dont know how to do them. When the installation is complete, add %MPI_ROOT%\bin to your System PATH environment variable. To cache your Windows password, open a Command Prompt window and run: "%AWP_ROOT130%\ansys\hpmpi\sethpmpipassword" . I highly appreciate in advance, |
Is this for CFX or FLUENT? If it's FLUENT try the FLUENT forum.
Hi.
Actually, because there is no "comment" on the installation wizard about how to activate PARALLEL in CFX I thought it may be related to both of them. As I know HPMPI is used in CFX as well, So, that's the reason that i posted this question in both FLUENT and CFX.... Thanks for your attention |
All the required parallel libraries for CFX are installed by default in 13.0.
