Home > Forums > CFX
How to make this draw in 3D
Old   January 22, 2012, 16:47
Default How to make this draw in 3D
kbaker's Avatar
Khalid Baker
kbaker is on a distinguished road
I want to draw 3D pipe inlet as 2 inlets one for Air and the other for Water as shown in picture may somebody tell me to how i can draw it and use it in CFX?
kbaker is offline   Reply With Quote
Old   January 22, 2012, 18:51
ghorrocks is a jewel in the roughghorrocks is a jewel in the roughghorrocks is a jewel in the rough
This is trivial to draw in any solid modelling package or DesignModeller. If you cannot work out how then do some tutorials on your solid modellign package of choice.
If this is a multiphase simulation why can't you use a single inlet and use the volume fraction to define the air and water sections?
ghorrocks is online now   Reply With Quote
Old   January 23, 2012, 06:39
kbaker's Avatar
Khalid Baker
Hi thanks for the reply If I use single inlet how I can define the shape of the interface as you see from the pict my interface is concave not flat ? I think your idea is right with flat interface not concave? also i am new with CFX?
Old   January 23, 2012, 06:47
You have to define a CEL expression which evaluates to 0 in the air region and 1 in the water region (for the water VF). In this case the interface looks circular so an equation which gives the distance from the centre point should do the trick, as you use an if statement to assess whether it is inside or outside your defined arc.
Old   January 23, 2012, 15:37
kbaker's Avatar
Khalid Baker
Thanks for the reply as I told you I am new with CFX what you mean with CEL expression? what you advice me to read to start simulation my case with CFX?
Old   January 23, 2012, 17:36
CEL is the CFX expression language. You can see how it works in the tutorials as many of them use CEL functions.
Old   January 25, 2012, 03:42
kbaker's Avatar
Khalid Baker
may you sent me a web site for all CFX tutorials or sent it via my email below I am actually not have anyone.
khalidb77@gmail.com
Old   January 25, 2012, 03:59
Lance
Lance is on a distinguished road
khalidb77@gmail.com
You already have them, they are included in the installation. Just open Help/tutorials inside CFX or locate cfx_tutr.pdf inside the Ansys installation folder.
There's also a couple of examples on the ansys customer portal, have a look there.
Lance is offline   Reply With Quote
Old   January 25, 2012, 15:13
kbaker's Avatar
Khalid Baker
I found the cfx_tutr.pdf file but I not have any of mesh files, ccl files and out files and I do not have access for ansys customer portal I am so thankful if you kindly send me the related files for Tutorial (9) : Free surface flow over a Bump into my email.
Old   January 25, 2012, 15:17
Lance
... I not have any of mesh files, ccl files and out files
yes you do, look at:
<cfxroot>\CFX\examples
....I do not have access for ansys customer portal...
every customer should have access...
Old   January 29, 2012, 07:19
kbaker's Avatar
Khalid Baker
Dear ghorrocks I read and run the Free surface flow over a Bump tutorial available in examples folder its a good example in free surface flow If you remember for the pict i sent in my first post you told me that I need to define a CEL expression for vof for water to evaluate the shape of interface ? the problem I do not have equation define it only I have it's distance from the bottom of pipe so how i can define the convex interface in this case? any suggestions pls?
kbaker
Old   January 29, 2012, 18:42
To do this in a CEL expression you need to define an expression which describes the shape of the interface. This looks like a circle so that should not be too hard. Then you simply do a check (with step or if) whether the point is inside or outside the circle, and define the volume fraction.
Thread Tools
Trackbacks are On
Why can't I make the boundaries periodic? Alina FLUENT 5 April 12, 2012 14:06
how to draw journal bearing fluid using gambit?? zidane FLUENT 0 March 8, 2009 13:40
use of Gturbo to make turbine blade usman FLUENT 0 December 31, 2007 06:47
nEED Need Your Help to make a PACKAGE CODE Ghassem Main CFD Forum 0 February 24, 2000 13:38
[Q]How to make MPEGs with CFD datas??? Bum-Seok Hyun Main CFD Forum 4 February 16, 2000 19:59
