Problem with CHT on a cooling device
Like Tree1Likes
  • 1 Post By ghorrocks
Old   February 6, 2012, 08:32
Default Problem with CHT on a cooling device
Anonymous
rideway is on a distinguished road
Hello everybody.
First of all, saying that this forum is great. I have been using it for weeks to get started into CFX. Now im doing my first project with it and i am already having trouble.
System is a simple cooling water pipe with several cupper pipes across it who deliver heat (lets say 1000w for the sake of the problem). I tried to follow the CFX-5 tutorial "Conjugate Heat Transfer in a Heating Coil" but it doesnt work. The hot pipes get inifinitely warm (10 million Celsius degrees!!) and cooling water doesnt change temperature.
I applied the 1000w heat to the subdomain, like in the tutorial, but when I tried applying this heat to the fluid walls in contact with the hot pipes it worked! But the thing is that I want to know which ΔT there is between cooling and hot pipes, so I need to know where my mistake is.
Can anyone give me a hint to solve this problem? Connectivity problems? Bad modelling?
Thank you very very very much!!!
Regards
rideway is offline   Reply With Quote
Old   February 6, 2012, 19:12
Sounds like you did not apply the interface between the solid and fluid domains.
rideway likes this.
Old   February 7, 2012, 03:46
Anonymous
Thanks a lot, you are right. The thing is that i still dont know why in the tutorial that Interface is not being defined... Anyway, it works perfectly!
Thanks Glenn
Old   February 7, 2012, 16:18
Because the interface is automatically detected from the two coincident faces. For some reason your faces were not detected as coincident, or you turned this checking off.
heat transfer cooling
About Cooling channel alefem FLOW-3D 1 May 28, 2010 11:15
Velocity profiles problem behind the elbow (3D problem) kabat73 FLUENT 8 May 9, 2010 04:26
Cooling simple 3D geometry problem Luk FLUENT 4 May 12, 2006 09:47
CHT strange problem MatejK CFX 3 September 1, 2005 05:32
CHT problem sch CFX 2 July 11, 2003 10:32
