December 5, 2011, 04:12 |
fan characteristics
Rep Power: 15 |
Hello everyone.
I simulate generator thermal behavior with the fan on the outlet side of the fan. But this fan contains many elements which increases computational effort during solving. My question is: Is it possible to replace the fan geometry with its characteristic (airflow vs. pressure drop)?? I heard that it is possible in Fluent but I don't know if it works in CFX. Any reply will help. Thanks a lot. |
December 5, 2011, 05:22 |
Rep Power: 143 |
Yes, use a momentum source and link the source term to an equation describing the fan characteristic curve.
December 5, 2011, 06:42 |
Rep Power: 15 |
Thanks a lot. Just another question on which domain should I put it?? I have several domains that define generator and I would need to know where to define this equation. Is it on inlet domain??
December 5, 2011, 16:42 |
Rep Power: 143 |
You can put sources on boundaries, or define sub-domains and apply it to volumes. Whatever is most appropriate in your case.
January 26, 2012, 08:20 |
Rep Power: 15 |
thanks a lot. I still have some issues concerning expressions. Is there any tutorial on that?
January 26, 2012, 16:23 |
Rep Power: 143 |
Several of the tutorials use CEL expressions. I am not in my usual office today so cannot list them for you but I know the free surface flow over a bump one uses it and so do several others.
January 27, 2012, 02:39 |
Rep Power: 15 |
ok I'll find them. thank you again glenn
Modeling a Fan by the Multiple reference frame (MRF) method in CFX. | saisanthoshm88 | CFX | 11 | February 17, 2021 11:30 |
Jet fan and Tunnel simulation | ahlo7 | CFX | 9 | November 13, 2019 04:54 |
Simulation of Axial Fan Flow using A Momentum Source Subdomain | Liam | CFX | 28 | July 16, 2013 08:24 |
Proper BCs for internal fan | serezhkin | CFX | 3 | July 28, 2010 10:04 |
Propeller Fan Curve Simulation | Teng_YJ | FLUENT | 2 | February 16, 2009 19:37 |
