February 1, 2012, 07:17 |
Follow the flowing of a gas
jean-françois jerier
Rep Power: 14 |
Hi all,
In my simulation, a gas (G1) is injected in a domain via a pump and it is purged via a vacuum pump (steady state phase). Then, I inject during a short period an other gas (G2) by a transient phase. Please, can you tell me how can I follow the flowing of the second gas (G2) in the CFD-post, so as to know if G2 is well evacuated in a fixed time. Thank you in advance for your help |
February 1, 2012, 14:17 |
Dustin
Rep Power: 14 |
syens,
This sounds like a straight-forward transient analysis (maybe I'm missing something). You should calculate roughly the time it would take for one particle of Gas 2 to enter and exit the pipe. That will govern your timestep. Your initial conditions can be set up so that it starts with 100% Gas 1 and 0% Gas 2 (Mass Fraction 1 and 0), then giving Gas 1 and Gas 2 an initial condition (velocity maybe). You will also want to stop injecting Gas 2 after a preset time (someone else will have to tell you how to do this). In CFX-Post, you could then animate the transient, or look at each time step. I skipped over some things, since this stuff is in the tutorials, but correct me if this is more complicated than I thought. |
February 2, 2012, 02:28 |
Rep Power: 14 |
Hi Trues,
Thank you for your reply, I think that everything in the CFX-Pre is defined : _ The steady state phase (P1) to install the gas G1 _ The transient phases to inject G2 (P2) and evacuate (P3) the gases. During the phase P3, the injection of gas G2 is stopped and G1 is injected. In the domain, I have solid parts and I want to follow the flowing of G2 through the domain. Do you know how can I visualize with the streamline or vector the flowing of G2 during P2 and P3 ? Short version: Is it possible in the CFD-Post to visualize by streamlines or vectors the flowing of defined material for a transient phase ? |
February 2, 2012, 04:41 |
Rep Power: 143 |
Yes, you can define streamlines to be calculated from any vector variable field. But note streamlines are a bit weird in transient flows. You might want to use massless particles or additional variables (passive scalars) if you want to track where stuff gets to. But if you already have a multiphase or multicomponent mixture simulation you can simply do isosurfaces of the phases/components.
February 2, 2012, 11:04 |
Rep Power: 14 |
Hi
Thank you for your reply !!! I read this previous discussion (http://www.cfd-online.com/Forums/cfx...x-5-7-1-a.html), but in the CFX-Pre, into the output section for transient phase, the option: the monitor particles section is full. I cannot choose the density of the particles !!! In CFX-Post, I can visualise the flowing with the symbol BALL in the streamline section. Is this type of visualisation, you mentionned in your post ? Regards JF |
February 2, 2012, 11:49 |
Dustin
Rep Power: 14 |
You could visualize isosurfaces of a specified gas 2 concentration (if you want a 3D picture), as ghorrocks suggested.
If you want a 2D visualization of the flow, why don't you just look at gas 2 mass fraction? you can step through time to watch gas 2 enter and exit |
mass flow in is not equal to mass flow out | saii | CFX | 12 | March 19, 2018 05:21 |
Gas flowing into a complex structure | syens | CFX | 1 | December 6, 2011 05:25 |
Constant velocity of the material | Sas | CFX | 15 | July 13, 2010 08:56 |
quantity of gas flowing through a pipe | Prem Siril | Main CFD Forum | 0 | June 7, 2004 05:36 |
Gas pressure question | Dan Moskal | Main CFD Forum | 0 | October 24, 2002 22:02 |
