Does mesh refinement affect solver?
Old   May 24, 2018, 09:10
Question Does mesh refinement affect solver?
Young Gun Lee
cltkgkdk is on a distinguished road
I was trying to simulate fluid flow through a channel with different size of mesh.
I've tried 80k, 104k, 174k, 192.5k, and 260k no. of mesh. They all converges well, but when I try 240k mesh, error occurs during solver.
I'm sure that same boundary conditions were applied.
cltkgkdk is offline   Reply With Quote
Old   May 24, 2018, 18:29
The numerical scheme in CFX is dissipative (just as for all solvers I know of). When you run a coarse mesh the numerical scheme adds dissipation which helps stabilise the convergence. As you refine the mesh the dissipation reduces and there comes a point when the stability is not adequate to converge. This is normal CFD solver behaviour.
If you find you need the fine mesh solution you will probably have to run transient to get it to converge.
Note: I do not answer CFD questions by PM. CFD questions should be posted on the forum.
convergence, mesh, solver
[snappyHexMesh] Multi Region Mesh of a car filter Zephiro88 OpenFOAM Meshing & Mesh Conversion 3 September 11, 2019 19:34
[snappyHexMesh] problems generating clean mesh Christian_tt OpenFOAM Meshing & Mesh Conversion 2 June 20, 2019 05:39
[snappyHexMesh] sHM refinement away from surface nholt OpenFOAM Meshing & Mesh Conversion 1 June 14, 2016 14:36
[snappyHexMesh] SHM problem : KVLCC2 with appendage mesh sc.park OpenFOAM Meshing & Mesh Conversion 1 March 13, 2016 13:28
[snappyHexMesh] Propeller mesh not smooth nortanapura OpenFOAM Meshing & Mesh Conversion 0 May 16, 2014 03:26
