Error ?
What does this error mean:
ERROR #001100279 has occurred in subroutine ErrAction. | | Message: | | SYMASS_ZIFCS_EL : The solver ran out of temporary space while bui- | | lding a linked list for a domain interface. Try setting the expe- | | rt parameter "topology estimate factor zif" to a value greater th- | | an 1.0. Values higher than 1.2 should not be necessary. I tried values of 2.0+, but still the same error... Could anyone take a look at my model? Thanks! |
The error is saying it is having a hard time assembling your interface. I would remesh and try to improve the mesh quality around the interface.
Make sure you really did set "topology estimate factor zif" and not a very similar parameter that is in the GUI. I think you have to set "topology estimate factor zif" via CCL.
How do I get to CCL?
Ok, I got it to solve without errors. But now my results show no motion even though I have a rotational device inside of a fluid... but nothing moves..
Is it a steady state or transient run? Have you run it long enough to see motion? Is the rotating bit transient rotor-stator of some other form of motion?
Well of course if the simulation is steady state then nothing is going to move at all. Doesn't that explain the lack of motion?
Can you post an image of the results and what you are trying to model?
I assume the fan rotates and generates a flow. What is the interface which caused the initial problem? Can you post your CCL?
Sorry, how do I get to the CCL?
Is this it? +--------------------------------------------------------------------+ | Mesh Statistics | +--------------------------------------------------------------------+ | Domain Name | Orthog. Angle | Exp. Factor | Aspect Ratio | +----------------------+---------------+--------------+--------------+ | | Minimum [deg] | Maximum | Maximum | +----------------------+---------------+--------------+--------------+ | Domain 1 | 90.0 OK | 1 OK | 1 OK | | Domain 2 | 60.9 OK | 3 OK | 2 OK | | Domain 3 | 38.4 ok | 10 ok | 7 OK | | Global | 38.4 ok | 10 ok | 7 OK | +----------------------+---------------+--------------+--------------+ | | %! %ok %OK | %! %ok %OK | %! %ok %OK | +----------------------+---------------+--------------+--------------+ | Domain 1 | 0 0 100 | 0 0 100 | 0 0 100 | | Domain 2 | 0 0 100 | 0 0 100 | 0 0 100 | | Domain 3 | 0 1 99 | 0 2 98 | 0 0 100 | | Global | 0 <1 100 | 0 <1 100 | 0 0 100 | +----------------------+---------------+--------------+--------------+ Domain Name : Domain 1 Total Number of Nodes = 40560 Total Number of Elements = 36875 Total Number of Hexahedrons = 36875 Total Number of Faces = 7150 Domain Name : Domain 2 Total Number of Nodes = 24990 Total Number of Elements = 20160 Total Number of Prisms = 960 Total Number of Hexahedrons = 19200 Total Number of Faces = 10440 Domain Name : Domain 3 Total Number of Nodes = 6497 Total Number of Elements = 21045 Total Number of Tetrahedrons = 21045 Total Number of Faces = 10864 Global Statistics : Global Number of Nodes = 72047 Global Number of Elements = 78080 Total Number of Tetrahedrons = 21045 Total Number of Prisms = 960 Total Number of Hexahedrons = 56075 Global Number of Faces = 28454 +--------------------------------------------------------------------+ | Reference Pressure Information | +--------------------------------------------------------------------+ Domain Group: Domain 1 Pressure has not been set at any boundary conditions. The pressure will be set to 0.00000E+00 at the following location: Domain : Domain 1 Node : 1 (equation 1) Coordinates : ( 1.16840E-01, 1.16840E-01, 2.83513E-01). +--------------------------------------------------------------------+ | Average Scale Information | +--------------------------------------------------------------------+ Domain Name : Domain 1 Global Length = 3.4007E-01 Minimum Extent = 2.5400E-01 Maximum Extent = 6.0960E-01 Density = 1.1850E+00 Dynamic Viscosity = 1.8310E-05 Velocity = 0.0000E+00 Domain Name : Domain 2 Global Length = 7.9063E-02 Minimum Extent = 1.1172E-01 Maximum Extent = 1.5240E-01 Density = 2.7020E+03 Thermal Conductivity = 2.3700E+02 Specific Heat Capacity at Constant Pressure = 9.0300E+02 Thermal Diffusivity = 9.7135E-05 Average Timescale = 6.4354E+01 Minimum Timescale = 1.2849E+02 Maximum Timescale = 2.3911E+02 Domain Name : Domain 3 Global Length = 2.4039E-02 Minimum Extent = 1.2700E-02 Maximum Extent = 8.9638E-02 Density = 2.7020E+03 Thermal Conductivity = 2.3700E+02 Specific Heat Capacity at Constant Pressure = 9.0300E+02 Thermal Diffusivity = 9.7135E-05 Average Timescale = 5.9494E+00 Minimum Timescale = 1.6605E+00 Maximum Timescale = 8.2720E+01 Subsystem : Momentum and Mass U-Mom-Domain 1 --> U-Mom V-Mom-Domain 1 --> V-Mom W-Mom-Domain 1 --> W-Mom P-Mass-Domain 1 --> P-Mass Subsystem : Heat Transfer - 1 T-Energy-Domain 2 --> T-Energy-Domain 2 Subsystem : Heat Transfer - 2 T-Energy-Domain 3 --> T-Energy-Domain 3 Subsystem : TurbKE and Diss.K K-TurbKE-Domain 1 --> K-TurbKE E-Diss.K-Domain 1 --> E-Diss.K CFD Solver started: Thu Feb 09 17:20:52 2012 | Timescale Information | ---------------------------------------------------------------------- | Equation | Type | Timescale | +----------------------+------------------------+--------------------+ | U-Mom-Domain 1 | Auto Timescale | 2.24540E+03 | | V-Mom-Domain 1 | Auto Timescale | 2.24540E+03 | | W-Mom-Domain 1 | Auto Timescale | 2.24540E+03 | +----------------------+------------------------+--------------------+ | T-Energy-Domain 2 | Auto Timescale | 6.43536E+01 | +----------------------+------------------------+--------------------+ | T-Energy-Domain 3 | Auto Timescale | 5.94942E+00 | +----------------------+------------------------+--------------------+ | K-TurbKE-Domain 1 | Auto Timescale | 2.24540E+03 | | E-Diss.K-Domain 1 | Auto Timescale | 2.24540E+03 | +----------------------+------------------------+--------------------+ ================================================== ==================== OUTER LOOP ITERATION = 1 CPU SECONDS = 1.326E+00 ---------------------------------------------------------------------- | Equation | Rate | RMS Res | Max Res | Linear Solution | +----------------------+------+---------+---------+------------------+ | U-Mom | 0.00 | 0.0E+00 | 0.0E+00 | 0.0E+00 OK| | V-Mom | 0.00 | 0.0E+00 | 0.0E+00 | 0.0E+00 OK| | W-Mom | 0.00 | 0.0E+00 | 0.0E+00 | 0.0E+00 OK| | P-Mass | 0.00 | 0.0E+00 | 0.0E+00 | 8.4 0.0E+00 OK| +----------------------+------+---------+---------+------------------+ | T-Energy-Domain 2 | 0.00 | 1.9E-06 | 9.7E-06 | 5.3 4.9E-03 OK| +----------------------+------+---------+---------+------------------+ | T-Energy-Domain 3 | 0.00 | 1.4E-06 | 6.8E-06 | 6.6 9.7E-03 OK| +----------------------+------+---------+---------+------------------+ | K-TurbKE | 0.00 | 1.8E+00 | 1.9E+00 | 5.1 2.2E-08 OK| | E-Diss.K | 0.00 | 6.3E+00 | 6.5E+00 | 7.5 2.5E-08 OK| +----------------------+------+---------+---------+------------------+ CFD Solver finished: Thu Feb 09 17:20:54 2012 CFD Solver wall clock seconds: 2.0000E+00 +--------------------------------------------------------------------+ | U-Mom-Domain 1 | +--------------------------------------------------------------------+ +--------------------------------------------------------------------+ | V-Mom-Domain 1 | +--------------------------------------------------------------------+ +--------------------------------------------------------------------+ | W-Mom-Domain 1 | +--------------------------------------------------------------------+ +--------------------------------------------------------------------+ | P-Mass-Domain 1 | +--------------------------------------------------------------------+ +--------------------------------------------------------------------+ | T-Energy-Domain 2 | +--------------------------------------------------------------------+ +--------------------------------------------------------------------+ | T-Energy-Domain 3 | +--------------------------------------------------------------------+ +--------------------------------------------------------------------+ | Locations of Maximum Residuals | +--------------------------------------------------------------------+ | Equation | Node # | X | Y | Z | +--------------------------------------------------------------------+ | U-Mom-Domain 1 | 0 | 0.000E+00 | 0.000E+00 | 0.000E+00 | | V-Mom-Domain 1 | 0 | 0.000E+00 | 0.000E+00 | 0.000E+00 | | W-Mom-Domain 1 | 0 | 0.000E+00 | 0.000E+00 | 0.000E+00 | | P-Mass-Domain 1 | 0 | 0.000E+00 | 0.000E+00 | 0.000E+00 | | T-Energy-Domain 2 | 15473 |-3.063E-02 | 3.395E-02 |-2.540E-02 | | T-Energy-Domain 3 | 1505 | 6.033E-03 | 2.596E-02 | 8.733E-04 | | K-TurbKE-Domain 1 | 29304 |-9.652E-02 |-1.168E-01 | 2.628E-01 | | E-Diss.K-Domain 1 | 17096 |-5.080E-03 | 4.572E-02 | 1.182E-01 | +--------------------------------------------------------------------+ +--------------------------------------------------------------------+ | Peak Values of Residuals | +--------------------------------------------------------------------+ | Equation | Loop # | Peak Residual | Final Residual | +--------------------------------------------------------------------+ | U-Mom-Domain 1 | 0 | 0.00000E+00 | 0.00000E+00 | | V-Mom-Domain 1 | 0 | 0.00000E+00 | 0.00000E+00 | | W-Mom-Domain 1 | 0 | 0.00000E+00 | 0.00000E+00 | | P-Mass-Domain 1 | 0 | 0.00000E+00 | 0.00000E+00 | | T-Energy-Domain 2 | 1 | 1.91960E-06 | 1.91960E-06 | | T-Energy-Domain 3 | 1 | 1.35297E-06 | 1.35297E-06 | | K-TurbKE-Domain 1 | 1 | 1.78790E+00 | 1.78790E+00 | | E-Diss.K-Domain 1 | 1 | 6.34034E+00 | 6.34034E+00 | +--------------------------------------------------------------------+ +--------------------------------------------------------------------+ | False Transient Information | +--------------------------------------------------------------------+ | Equation | Type | Elapsed Pseudo-Time | +--------------------------------------------------------------------+ | U-Mom-Domain 1 | Auto | 2.24540E+03 | | V-Mom-Domain 1 | Auto | 2.24540E+03 | | W-Mom-Domain 1 | Auto | 2.24540E+03 | | T-Energy-Domain 2 | Auto | 6.43536E+01 | | T-Energy-Domain 3 | Auto | 5.94942E+00 | | K-TurbKE-Domain 1 | Auto | 2.24540E+03 | | E-Diss.K-Domain 1 | Auto | 2.24540E+03 | +--------------------------------------------------------------------+ +--------------------------------------------------------------------+ | Average Scale Information | +--------------------------------------------------------------------+ Domain Name : Domain 1 Global Length = 3.4007E-01 Minimum Extent = 2.5400E-01 Maximum Extent = 6.0960E-01 Density = 1.1850E+00 Dynamic Viscosity = 1.8310E-05 Velocity = 0.0000E+00 Domain Name : Domain 2 Global Length = 7.9063E-02 Minimum Extent = 1.1172E-01 Maximum Extent = 1.5240E-01 Density = 2.7020E+03 Thermal Conductivity = 2.3700E+02 Specific Heat Capacity at Constant Pressure = 9.0300E+02 Thermal Diffusivity = 9.7135E-05 Average Timescale = 6.4354E+01 Minimum Timescale = 1.2849E+02 Maximum Timescale = 2.3911E+02 Temperature Range = 6.1035E-05 Domain Name : Domain 3 Global Length = 2.4039E-02 Minimum Extent = 1.2700E-02 Maximum Extent = 8.9638E-02 Density = 2.7020E+03 Thermal Conductivity = 2.3700E+02 Specific Heat Capacity at Constant Pressure = 9.0300E+02 Thermal Diffusivity = 9.7135E-05 Average Timescale = 5.9494E+00 Minimum Timescale = 1.6605E+00 Maximum Timescale = 8.2720E+01 Temperature Range = 6.1035E-05 +--------------------------------------------------------------------+ | Variable Range Information | +--------------------------------------------------------------------+ Domain Name : Domain 1 +--------------------------------------------------------------------+ | Variable Name | min | max | +--------------------------------------------------------------------+ | Density | 1.18E+00 | 1.18E+00 | | Specific Heat Capacity at Constant Pressure| 1.00E+03 | 1.00E+03 | | Dynamic Viscosity | 1.83E-05 | 1.83E-05 | | Thermal Conductivity | 2.61E-02 | 2.61E-02 | | Static Entropy | 0.00E+00 | 0.00E+00 | | Velocity u | 0.00E+00 | 0.00E+00 | | Velocity v | 0.00E+00 | 0.00E+00 | | Velocity w | 0.00E+00 | 0.00E+00 | | Pressure | 0.00E+00 | 0.00E+00 | | Turbulence Kinetic Energy | 4.77E-07 | 1.99E-01 | | Turbulence Eddy Dissipation | 6.10E-05 | 1.40E+01 | | Eddy Viscosity | 2.65E-10 | 3.05E-04 | | Temperature | 2.98E+02 | 2.98E+02 | +--------------------------------------------------------------------+ Domain Name : Domain 2 +--------------------------------------------------------------------+ | Variable Name | min | max | +--------------------------------------------------------------------+ | Density | 2.70E+03 | 2.70E+03 | | Specific Heat Capacity at Constant Pressure| 9.03E+02 | 9.03E+02 | | Thermal Conductivity | 2.37E+02 | 2.37E+02 | | Static Entropy | 0.00E+00 | 0.00E+00 | | Temperature | 2.98E+02 | 2.98E+02 | | Static Enthalpy | -3.12E-02 | 3.12E-02 | +--------------------------------------------------------------------+ Domain Name : Domain 3 +--------------------------------------------------------------------+ | Variable Name | min | max | +--------------------------------------------------------------------+ | Density | 2.70E+03 | 2.70E+03 | | Specific Heat Capacity at Constant Pressure| 9.03E+02 | 9.03E+02 | | Thermal Conductivity | 2.37E+02 | 2.37E+02 | | Static Entropy | 0.00E+00 | 0.00E+00 | | Temperature | 2.98E+02 | 2.98E+02 | | Static Enthalpy | -3.12E-02 | 3.12E-02 | +--------------------------------------------------------------------+ +--------------------------------------------------------------------+ | CPU Requirements of Numerical Solution | +--------------------------------------------------------------------+ Subsystem Name Discretization Linear Solution (secs. %total) (secs. %total) ---------------------------------------------------------------------- Momentum and Mass 1.01E+00 23.9 % 3.12E-01 7.4 % Heat Transfer - 1 7.80E-02 1.8 % 3.12E-02 0.7 % Heat Transfer - 2 6.24E-02 1.5 % 1.56E-02 0.4 % TurbKE and Diss.K 2.34E-01 5.5 % 1.09E-01 2.6 % -------- ------- -------- ------ Subsystem Summary 1.39E+00 32.7 % 4.68E-01 11.0 % Variable Updates 2.81E-01 6.6 % File Reading 1.56E-02 0.4 % File Writing 2.34E-01 5.5 % Miscellaneous 1.86E+00 43.8 % -------- Total 4.24E+00 +--------------------------------------------------------------------+ | Job Information | +--------------------------------------------------------------------+ End of solution stage. |
No, the CCL is the stuff in the first section of the output file - the bit you chopped off.
But I can see you have three domains and do not appear to have any interfaces to connect them. Also your fluid domain does not have a temperature/heat equation so cannot be linked to your solid domains. Looks like you have made some pretty basic setup errors with this simulation. I recommend you do the tutorials on conjugate heat transfer, that is ones with solid and fluid bodies coupled together. |
Thanks!
I actually did the Ch 17 Tutorial: Multiphase Flow in a Mixing Vessel... It was helpful, but actually confused me quite a bit. Do you have to model fluid around the propeller and fluid inside the tank separately? That part confused me... How many components do I need to solve my problem? Just the fan, tube, and fluid... so 3 parts? |
Do some of the rotating machinery tutorials to see how you model rotating devices.
I think I have it now -- BTW Ch 17 is turbomachinery tutorial
How do you create a subregion within your meshes? It looks like that's the problem I'm running into.
