Velocity drop over backward facing step
Old   February 9, 2012, 09:52
Default Velocity drop over backward facing step
warlocklw is on a distinguished road
Velocity will drop over step height at backward facing step. However, the drop rate differ if the inlet velocity changed, that is Reynolds Number changed.
Can someone explain why the velocity drop more gradual if Re increase, while low Re will have sharper velocity drop rate? Thanks in advanced.
warlocklw is offline   Reply With Quote
Old   February 9, 2012, 16:06
Have you looked at the flow fields? I think you will find as you increase Re number over this range the separation gets more pronounced, meaning that the velocity slow down and pressure recovery associated with the flow over the step gets spread over a longer distance.
Old   February 9, 2012, 21:24
Yes, the recirculation zone size increase with Re. Thanks for your explanation.
Incompressible Navier-Stokes equations for a backward facing step werder85 Main CFD Forum 1 January 3, 2011 16:19
backward facing step flow gopinath Main CFD Forum 0 January 22, 2005 05:02
Backward Facing Step Nathan Molyneaux Main CFD Forum 1 August 8, 2004 07:47
Backward Facing Step Jimmy Main CFD Forum 3 July 25, 2004 22:37
Backward Facing Step Pete Main CFD Forum 5 June 28, 2000 21:40
