doubt in applying boundary condition
Old   February 10, 2012, 21:10
Default doubt in applying boundary condition
Shashwat
shaswat is on a distinguished road
Dear friends
problem: Fluid is flowing through a multilayer porous pipe.
I know the boundary conditions for inlet which is pressure and outlet which is mass flow rate in the fluid domain
my question is:
How to define inlet and out let in the porous domain.
I assume in the porous domain as
inlet: Cartesian velocity components equal to 0
outlet : pressure equal to 0
Is my boundary condition correct?
Thank you
Regards
Shashwat
shaswat is offline   Reply With Quote
Old   February 11, 2012, 05:36
If that matches the experiment you are trying to model then probably, yes.
But it does seem weird to have a mass flow outlet on the main flow, but zero pressure at the porous outlet. Why is it different? If the flow is not significant in the porous material just put a wall there.
Wind turbine simulation Saturn CFX 58 July 3, 2020 01:13
problem with boundary condition??? smn CFX 5 November 24, 2009 06:37
RPM in Wind Turbine Pankaj CFX 9 November 23, 2009 04:05
how to set up a wall boundary condition according to calculated wall shear stress? gameoverli OpenFOAM Pre-Processing 1 May 21, 2009 08:28
Convective Heat Transfer - Heat Exchanger Mark CFX 6 November 15, 2004 15:55
