February 10, 2012, 21:10 |
doubt in applying boundary condition
Shashwat
Dear friends
problem: Fluid is flowing through a multilayer porous pipe. I know the boundary conditions for inlet which is pressure and outlet which is mass flow rate in the fluid domain my question is: How to define inlet and out let in the porous domain. I assume in the porous domain as inlet: Cartesian velocity components equal to 0 outlet : pressure equal to 0 Is my boundary condition correct? Thank you Regards Shashwat |
February 11, 2012, 05:36 |
Rep Power: 143 |
If that matches the experiment you are trying to model then probably, yes.
But it does seem weird to have a mass flow outlet on the main flow, but zero pressure at the porous outlet. Why is it different? If the flow is not significant in the porous material just put a wall there. |
Wind turbine simulation | Saturn | CFX | 58 | July 3, 2020 01:13 |
problem with boundary condition??? | smn | CFX | 5 | November 24, 2009 06:37 |
how to set up a wall boundary condition according to calculated wall shear stress? | gameoverli | OpenFOAM Pre-Processing | 1 | May 21, 2009 08:28 |
