Home > Forums > CFX
VOF in CFX
Like Tree2Likes
  • 2 Post By ghorrocks
Old   February 12, 2012, 16:20
Question VOF in CFX
Taleb Zarei
talebzarei is on a distinguished road
I wanna to use from VOF framework in my gas-liquid system simulation but I couldnt active VOF in CFX software. How can I active VOF in CFX pre?. What should I do in Defult domain?
talebzarei is offline   Reply With Quote
Old   February 12, 2012, 18:01
ghorrocks is a jewel in the roughghorrocks is a jewel in the roughghorrocks is a jewel in the rough
Do the tutorial on free surface flow over a bump - this will show how to set up VOF style simulations.
talebzarei and wwjshirley like this.
Old   February 13, 2012, 16:10
Taleb Zarei
Thanks
I will read this tutorial
Old   February 25, 2012, 23:04
K.M.Yang
aximefu is on a distinguished road
Then which one is about the euler-euler model? Thanks!
aximefu is offline   Reply With Quote
Old   February 26, 2012, 05:10
Can't remember off the top of my head (I do not have CFX in front of me). Just go through the contents page of the tutorial documentation and the eular-eular examples should be obvious.
Old   February 26, 2012, 09:03
K.M.Yang
OK, I will find it out.
Another question: do you have some material about the difinition and distinguish of eular-eular、VOF or Euler lagrange or where I can download some?
Recently, I am working on phase change in heat pipe, and confused about the models used in CFD multiphase flow simulation.
Thanks!
Old   February 26, 2012, 18:04
I think the documentation has comments on selecting multiphase models. Try the modelling one.
The line between the multiphase models is blurry and for many models a number of multiphase approaches will work.
* Free surface modelling + homogeneous equations - two or more phases have a resolvable interface and never mix at a scale smaller than the mesh.
* Free surface modelling + inhomogeneous equations - two or phases have a resolvable interface but sometimes mix at a scale smaller than the mesh.
* Eular-Eular modelling - No resolvable interface so all mixing is at a scale smaller then the mesh.
* Particle tracking - individual phase bits (eg sand, bubbles in water, droplets in air) can be tracked in the continuous phase as a discrete particles.
Note the mesh size comes into the choice - whether the phases are mixed at a level you mesh can resolve. This means you have to be careful with mesh refinement studies and excessive mesh refinement as you may change the regime you are operating in.
Old   March 2, 2012, 03:46
K.M.Yang
Thank you for your answer!
I have read the Help file for CFX,and I think the model -free surface modeling+ inhomogeneous model you mentioned is equivalent to particle model or mixture model, so which model in cfx is equivalent to the model "eular-eular modeling"?
Do you know something about it? If you do, pls tell me. Thanks!
PS:
In Fluent, There are two Multiphase Models:Euler-lagrange model and Euler-euler model. Euler-euler model has three sub-model: VOF, mixture and euler, corresponding to specific different settings.
Is there have the similar sketch of Multiphase models in CFX?
Old   March 2, 2012, 07:54
I have no idea what the Fluent terms are referring to. I will leave it up to you to compare the documentation and see which options are equivalent.
Old   March 2, 2012, 10:26
K.M.Yang
I will have a try!
Old   March 28, 2012, 04:42
Default Multi phase combustion using CFX
  #11
manjunath
Gandhi is on a distinguished road
How to do Homogeneous chemical reaction in cfx
like when liquid sodium reacts with water vapour hydrogen bubble is generated, it has to to be separate phase. plz help me in doing this in CFX or Fluent
Gandhi is offline   Reply With Quote
Old   March 29, 2012, 05:53
I think you will have to ask CFX support for an example file of this sort of simulation.
Thread Tools
Trackbacks are On
CFX Treatment of Laminar and Turbulent Flows Jade M CFX 14 June 15, 2016 09:36
CFX pressure in Simulations problem nasdak CFX 1 April 14, 2010 13:22
Different flow pattern between OpenFOAM and CFX AirS OpenFOAM 0 January 12, 2010 08:08
heat generation in CFX Ema CFX 4 August 7, 2009 05:39
CFX 10's solutions differ from CFX 5.7's Atit Koonsrisuk CFX 4 July 26, 2006 11:59
