-   -   error message cfx solver (http://www.cfd-online.com/Forums/cfx/97241-error-message-cfx-solver.html)
sherlock303 February 13, 2012 06:48
hello
The solver stopped my simulations after 49 timesteps given the following error message:
| The ANSYS CFX solver could not be started, or exited with return |
| code 255: . No results file has been created.
I've changed the the wind velocity from 32m/s to 20m/s and try a second time, but the solver stopped after 46 timesteps.
However,when I ran another simple tutorial example ,the problem did not happen.
I wonder whether there are problems in mesh.Here are the datas.
DeterminantMin = 0.782659, max = 1, mean = 0.962677437883
268122 elements with the "Determinant" diagnostic
559433 elements for which this diagnostic is undefined
Aspect ratio:0.00331543, max = 349.772, mean = 11.1167417468
746314 elements with the "Aspect ratio" diagnostic
81241 elements for which this diagnostic is undefined
miniangle:Min = 0, max = 90, mean = 44.4654433844
827555 elements with the "Min angle" diagnostic
0 elements for which this diagnostic is undefined
http://www.cfd-online.com/Forums/mem...e335-213-1.png http://www.cfd-online.com/Forums/mem...ure334-213.png
thanks in advance
ghorrocks February 13, 2012 07:28
Can you post the output file? The snippet you show is not very useful.
I suspect the problem is with writing results files, but that is just a guess.
sherlock303 February 13, 2012 09:11
which format of the file? def, tin ,ccl?
ghorrocks February 13, 2012 17:36
CCL or output file. They are text files and should be small enough to post on the forum (possibly as an attachment).
sherlock303 February 13, 2012 21:20
2 Attachment(s)
here are the ccl and outputfile
ghorrocks February 14, 2012 17:35
The cfx5 file is a meshing file. Discuss that issue on the meshing forum - but the error message in the file is pretty clear.
I cannot see anything too unusual in your CCL file. You have not included the solver out file.
