-   -   FSI Solution Error (http://www.cfd-online.com/Forums/cfx/97584-fsi-solution-error.html)
sheth February 21, 2012 00:47
FSI Solution Error
I am trying to work on the Oscillating Plate Tutorial of CFX, I followed all directions properly given in the manual.
But while runnnig solution, the following error occurs:
Setting up CFX Solver run ...
| Processing ANSYS Input File (Running CCL2MF) |
Created C:\Documents and Settings\OFFICE\Local
Settings\Temp\1_3400_Working\dp0\CFX\CFX\Work1\Flu id
Flow_001.ansys\ANSYS.mf
| Starting ANSYS Solver |
| An error has occurred in cfx5solve: |
| ANSYS Solver terminated unexpectedly with return code 256 |
Can somebody please help.
Lance February 21, 2012 03:24
That is just the output from cfx, post the output from Ansys as well (ANSYS.stdout)
sheth February 21, 2012 04:41
Dear Lance
Thanks for reply.
Actually ANSYS output window was totally blank. In output control I have mentioned calculation of structure first and then CFX, I believe the error is due to ANSYS calculations and not CFX.
When I tried to compute only structure (No multifield), I got this error:
An error occurred while starting the ANSYS solver module. Please refer to the Troubleshooting section in the ANSYS Workbench Manual Project.
Lance February 21, 2012 05:05
Well, if you cannot run a normal structure analysis then you wont be able to run a FSI case either. It sounds like it is more related to your Ansys installation.
sheth February 21, 2012 05:23
Yes it may be. Can it be due to lack of computational memory? My computers are not specially assembled for CFD, they are not very high end ones.
sheth February 21, 2012 05:34
RESOLVED..... RE-INSTALLATION worked.
