copper viscosity!!!
Old   February 22, 2012, 04:55
Question copper viscosity!!!
Reza
gooya_kabir is on a distinguished road
Hi, at first thanks for your help:*
I run a multiphase flow, continuous liquid(water) with dispersed solid(copper).
in pre setup, this message appear:
In Analysis 'Flow Analysis 1' - Domain 'Domain 1': The following materials require Viscosity to be defined: 'Copper'
but there is no box in material section to define viscosity, what do you think?
thanks alot
gooya_kabir is offline   Reply With Quote
Old   February 23, 2012, 08:23
Daniel Lai Ern Yoong
DanielLai is on a distinguished road
ya.. same here as well...another problem is
In Analysis 'Flow Analysis 1' - Domain 'fluid': The use of the 'Liquid Evaporation Model' in the component pair 'H2O | Water' requires the existence of a Homogeneous Binary Mixture that defines the Antoine coefficients.
.i already create the homogeneous binary mixture material.. but where to insert it to the fluid domain ????? thanks....
DanielLai is offline   Reply With Quote
Old   February 23, 2012, 11:10
Raja_Bhai
tauqirnawaz is on a distinguished road
Can you both please take a screen print of your Domain>Basic Settings?
tauqirnawaz is offline   Reply With Quote
Old   February 25, 2012, 00:46
Default print of basic setting
Reza
the attached file is a screen print of basic setting
thanks very much
Old   February 27, 2012, 07:07
Raja_Bhai
thanks very much
You would have to manually define a very small insignificant molecular viscosity of copper.
Click on material tab on top menu, and define a new material and name it "copper1". Use the following options,
Basic Settings>Option> Pure Substance
>Material Group>User
Define all the material properties as in predefined "Copper", you can now define viscosity as well in
Material Properties>Transport Properties>Dynamic Viscosity.
viscosity multiphase
Eulerian Modeling: Frictional Viscosity Help meangreen FLUENT 1 January 25, 2018 15:13
Too low temperature at combustor outlet romekr FLUENT 2 February 6, 2012 10:02
modelling solids viscosity in eulerian multiphase model derkaiser FLUENT 1 December 5, 2011 03:42
copper electrorefining helen.h FLUENT 0 April 15, 2011 15:57
kinematic viscosity at diff temperatures,pressures Mecobio Main CFD Forum 0 November 7, 2005 12:55
