another issue about HPC cluster for running cfx, hepl PLZ. |
March 4, 2012, 20:12 |
Safia
Rep Power: 15 |
Hi there
I'm now running ANSYS-CFX simulation via HPC cluster at my Uni. I used script file with the below command: cfx5solve -batch -double -def 2cmsteady.def -fullname 2cmsteady -monitor 2cmsteady.res -part $nnodes -par-local But, when I went through the out file, I found this words which means that double precision not active!!! +--------------------------------------------------------------------+ | | | CFX Command Language Upgrade | +-------------------------------------------------------------------- Added /SIMULATION CONTROL/EXECUTION CONTROL/EXECUTABLE SELECTION/Double Precision = Off. +--------------------------------------------------------------------+ | | | CFX Command Language for Run | | +-------------------------------------------------------------------- As well as, I run the same simulation on my own PC, and there is different between the resdual for both. So how I can run my simulation via hpc cluster with double precision to avoid run-off error!!! Finally, if I misunderstand any thing, please, tell me the meaning of this Double Precision = Off. Regards |
March 4, 2012, 22:33 |
Rep Power: 143 |
I thought that setting double precision at the commend line over-rode any setting from CFX-Pre but your comment suggests this is not so. In that case I would open it in CFX-Pre and toggle th double precision to on.
March 4, 2012, 22:56 |
need help
#3 | |
Safia
Rep Power: 15 |
And if you mean that I should open my .cfx file via hpc cluster, that what I did not and I do not know to control it. help me if you have further solutions to my problem. Regards |
March 4, 2012, 23:05 |
Got it
Safia
Rep Power: 15 |
got it,, I do not need any further explaination, thanks Glenn so much
March 4, 2012, 23:58 |
#5 | |
Safia
Rep Power: 15 |
Thanks for your good input, Glenn |
controls issue in cfx mesh | ben | CFX | 12 | January 20, 2012 03:27 |
CFX in Windows HPC 2008 | Srikanth | CFX | 5 | February 15, 2010 03:42 |
Turbomachinery Convergence Issue CFX 11 | sherifkadry | CFX | 0 | May 29, 2009 13:07 |
CFX distributed computing: Cluster design Q | Joe | CFX | 7 | July 11, 2006 10:21 |
Running CFX on a cluster | jvk | CFX | 9 | September 19, 2002 22:22 |
