CFX Solver Reynolds Number
Old   February 29, 2012, 23:34
Default CFX Solver Reynolds Number
Haider Muhammad
haider760 is on a distinguished road
Hello all,
I was simulating simple flow inside a pipe for seeing pressure drop and heat transfer during the flow. I found that Reynolds number that Cfx solver calculates is quite different from the theoretical Reynolds Number.
I went through different threads which states that because cfx uses length scale which is cube root of volume therefore we have this difference.
I have understanding that due to difference of Reynolds number physics of flow will change (i.e laminar flow will be in turbulence regime) and if i have to compare it with some correlation that are based on theoretical Reynolds number, then the comparison may not be appropriate.
I also defined theoretical Reynolds Number using additional variables, but i found that momentum equations are still solved using cfx solver calculated Reynolds Number.
I was wondering if there could be any way that i can define cfx solver reynolds number as the theoretical Reynolds number so that i can compare my results on an equal ground. Or should i ignore this difference in Reynolds Number and still compare my results?
Any help will be appreciated?
Thanks
Regards
Haider
haider760 is offline   Reply With Quote
Old   March 1, 2012, 17:01
You cannot change the Re number reported in the output file. It is just a guide as to what flow regime the flow is likely to be in, and it can be completely wrong. It is not used in the solver to set anything, it just triggers some warning messages (which can be ignored if not relevant). Just ignore it and use your own definition of Re number.
Old   March 4, 2012, 22:05
Haider Muhammad
Thanks Gorrocks!
It really cleared many doubts!
How to define the Reynolds Number in CFX? yflin CFX 27 November 24, 2018 04:20
Turbulence model for low Reynolds number flow? Nokadu Main CFD Forum 3 May 26, 2013 11:42
Two way particle coupling in OF 2.0 and the particle reynolds number preichl OpenFOAM 7 February 9, 2012 15:38
Reynolds Number and Heat transfer Coefficient panos_metal FLUENT 0 January 7, 2011 06:37
High Reynolds Number Incompressible Flow Nick Lavery Main CFD Forum 3 February 19, 2002 15:47
