-   -   Wind load on surface => Turbulence modelling (http://www.cfd-online.com/Forums/cfx/98294-wind-load-surface-turbulence-modelling.html)
pz1337 March 7, 2012 11:57
i am trying to modell the load on surface by the wind, using
- power law for the inlet velocity
- sand grain roughness on the ground
- keps or kw-sst modell
in ansys cfx 14.0
Wind velocity are hitting the surface around 15m/s. I have pressure measurements from a wind tunnel - but they do not match.
Can you advise me on
(1) which turbulence model is better?
(2) how can i (iteratively) see how fine i have to resolve the mesh near the surface?
Thanks a lot in advance!
pz1337 March 7, 2012 12:09
i get a converged solution using kw sst and a first cell height of 0.01m on the surface. When I changed that to 0.005m (Using Inflation, First Cell height@0.005m, max Layers: 15, ratio 1.2 to achieve a smooth transition to the sorrounding area).
I get very bad convergence, osciallating at around 5e-4 (comparing to 1e-6) before.
any advice on this? I am sure there is a simple explanation.
Thanks again
ghorrocks March 7, 2012 18:02
Have you seen these FAQ:
http://www.cfd-online.com/Wiki/Ansys...gence_criteria
http://www.cfd-online.com/Wiki/Ansys..._inaccurate.3F
pz1337 March 7, 2012 18:07
thank you - yes I have.
I am constantly working on the problem and was hoping for some suggestions to speed things up as I am working on the problem already for quite some time and each new calculation takes several hours.
