Home > Forums > CFX
Computational cost of transient turbulence model
Old   March 8, 2012, 13:55
Default Computational cost of transient turbulence model
Costin Ruja
costinruja is on a distinguished road
Send a message via Yahoo to costinruja
Good evening everybody,
I've recently began playing with some simulations of ahmed body in steady and transient conditions.For the steady state simulation i have been using 3 mesh densities and at the last case i had some problem with the convergence.This sounds to me like i managed to get past the dissipation limit of the SST model and the flow is flapping wild.So to get used to transient simulations and not to lock my computer the whole weekend i need some info on the computational expense of SAS SST, DES and LES (the main 3 turbulence models i understood are recommended for transient flow around bluff bodies).
Thanks,
Costin
costinruja is offline   Reply With Quote
Old   March 8, 2012, 18:10
ghorrocks is a jewel in the roughghorrocks is a jewel in the roughghorrocks is a jewel in the rough
You are correct in that the turbulence models you should consider are SAS, DES and LES.
The cost of these approaches depends on the model - the size of the turbulent structures they must model are dependant on the flow Re number, and the mesh must be adequate to resolve this so the mesh density will get higher as the Re number goes up.
But the SAS and DES approaches are much cheaper than LES as they only apply the LES approach in a subsection of the domain. Full LES does it everywhere and is obviously more expensive.
Thread Tools
Trackbacks are On
Turbulence postprocessing Mohsin FLUENT 0 September 19, 2011 21:05
build your own turbulence model with buoyancy Thomas Baumann OpenFOAM 11 November 23, 2009 09:53
v2-f turbulence model in CFX? flga CFX 14 November 23, 2006 07:12
Turbulence model Herry Phoenics 1 May 29, 2003 13:19
The cost of CFD efficiency Ben Metodiev Main CFD Forum 5 May 24, 2001 22:27
