-   -   Initial values files from Fluent to CFX (http://www.cfd-online.com/Forums/cfx/98690-initial-values-files-fluent-cfx.html)
Nabu March 16, 2012 08:04
Is it possible to use a result file from Fluent simulation as initial value for CFX simulation?
I have not found a file *.res , generally used as initial value in CFX, in the outputs of Fluent.
What type of file can i use?
Thanks
ghorrocks March 17, 2012 06:14
I am not sure how to do this. You might be able to get WorkBench to do the conversion for you if you set up a project with the result of the Fluent run going into a CFX run.
