Home > Forums > CFX
Physical parameters of water in CFX
Old   March 21, 2012, 04:00
Default Physical parameters of water in CFX
K.M.Yang
aximefu is on a distinguished road
In CFX what's the differences between physical parameters of water and water at 25℃. I want to simulate the phase change phenomenon between water and vapor, when choosing working fluids I don't know chich ones should be chosen.
If I choose water as a working fluid, the physical properities of which are the same with that of water at 25℃ when temperature is 25℃and different when temperature is not 25℃. Am I right?
aximefu is offline   Reply With Quote
Old   March 21, 2012, 06:20
ghorrocks is a jewel in the roughghorrocks is a jewel in the roughghorrocks is a jewel in the rough
If you are doing phase change stuff then if you use a constant properties material like water at 25C you will have an error, something like 10-20% at a guess, due to properties change. If you want to be more accurate than that you need to use variable properties - IAPWS is most accurate for water, it is a very accurate for water properties over just about any condition most people encounter - but it is much harder to converge.
If you are happy with a bit of an error then stick with fixed properties and your simulation will converge much easier. And definitely do all the simulation development (ie getting the phase change stuff working) using constant properties, and only flick over to IAPWS when it is working reliably.
Old   March 21, 2012, 06:38
K.M.Yang
Actually I met overflow problems very usually, but I don't sure if those were related to the fluid physical parameters' choosing.
Old   March 21, 2012, 06:42
That's why you should do development work with constant properties, and only switch to variable properties when everything else is working properly.
Old   March 21, 2012, 07:12
K.M.Yang
I just had a try with variable properities, and overflow appeared. It's hard to say which factor lead to the emergence of the problem.
Old   March 21, 2012, 17:37
Exactly. That's why you do development work on constant properties, and only when everything is working well do you turn on variable properties.
Old   March 21, 2012, 21:48
Safia
happy is on a distinguished road
Does this work even with air with variable properties. I used the air with subsonic mode. However, I have convergance issue when I used ideal air gas.
Regards
happy is offline   Reply With Quote
Old   March 21, 2012, 22:14
By constant or variable properties I mean things like viscosity and specific heat. Variable density is not regarded as variable properties, that is regarded as incompressible flow versus compressible flow. But compressible flow also has its own stability issues and increases the complexity of a simulation. Again, do not use a compressible solver unless the flow needs it.
Thread Tools
Trackbacks are On
Numerical oscillations in CFX with water boiling problem. michujo CFX 4 December 16, 2011 10:00
[ICEM] Proper way to name boundaries on 2D model for use in CFX? RossFS ANSYS Meshing & Geometry 4 November 10, 2011 03:38
PhD using CFX Rui CFX 9 May 28, 2007 05:59
Terrible Mistake In Fluid Dynamics History Abhi Main CFD Forum 12 July 8, 2002 09:11
uptodate water distribution network fredius,magige,tanzanian,(e.a) Main CFD Forum 0 January 27, 2002 08:10
