Boundary Type for the rotation Axis in CFX-Pre |
March 20, 2012, 11:00 |
Zhu Wentao
Rep Power: 15 |
What type of boundary should i take for the rotation axis in a 2.5D model.
thank you very much for the help PS: i use periodic interface for the both sides |
March 20, 2012, 16:17 |
Rep Power: 143 |
Assuming by 2.5D by mean an 2D axisymmetric simulation with an out-of-plane swirl component, or a 2D planar simulation with an out-of-plane component - then this can be done using a periodic boundary.
March 21, 2012, 07:43 |
but-...
Zhu Wentao
Rep Power: 15 |
thank you
but cfx-solve says there is no boundary at the xxx-position(where the rotation axis is). my question is which bounday should i select for the xxx(rotation axis)? symmetrie? free slip wall? |
March 21, 2012, 16:42 |
Rep Power: 143 |
If your geometry is a wedge then you do not need to define any boundary at the rotation axis. CFX does not have linear boundary conditions, only surface boundary conditions. Can you post an image of your geometry?
Problem with cyclic boundaries in Openfoam 1.5 | fs82 | OpenFOAM | 36 | January 7, 2015 00:31 |
Cyclic Boundary Condition | Luiz Eduardo Bittencourt Sampaio (Sampaio) | OpenFOAM Running, Solving & CFD | 36 | July 2, 2012 12:23 |
Need help with boundary conditions: open to atmosphere | Wolle | OpenFOAM | 2 | April 11, 2011 07:32 |
New topic on same subject - Flow around race car | Tudor Miron | CFX | 15 | April 2, 2004 06:18 |
Please help with flow around car modelling! | Tudor Miron | CFX | 17 | March 19, 2004 19:23 |
