March 23, 2012, 05:31 |
Nusselt number
Rep Power: 14 |
can anyone suggest me how to calculate the nusselt number from results?
I have a duct with L/D = 62 , ReD = 8100, all walls at constant heat flux. I want to cross check my results with Dittus- Boelter equation. pl. do reply |
March 25, 2012, 06:28 |
Rep Power: 143 |
Define a variable in CFD-Post with the equation for Nussult number. Then you can use this variable as a normal results file variable -you can plot it, get min/max, integrate it, graph it against something etc etc
March 27, 2012, 09:45 |
how to create variable Nussult no in cfd post
pritam gole
Rep Power: 14 |
i tried but not succeded in creating this varible with formula.......
please help |
March 27, 2012, 10:55 |
Rep Power: 14 |
how did u try pritam?
what is your formula? |
March 27, 2012, 15:06 |
Luis Filipe Fabiani
Rep Power: 17 |
On CFD-POST first create an expression
Example: sqrt(Velocity w^2) and name it ("nusselt", "my expression", or whatever) Then on variables, create a new variable (also name it as you wish) and point the "expression" field to the expression you just created. |
Nusselt number calculation in Fluent | Sharadkumar Yeri | FLUENT | 52 | May 29, 2019 06:29 |
why does nusselt number never reaches a fixed number when i plot it? | Ali taba | Main CFD Forum | 0 | January 5, 2012 17:34 |
[blockMesh] BlockMeshmergePatchPairs | hjasak | OpenFOAM Meshing & Mesh Conversion | 11 | August 15, 2008 07:36 |
[Commercial meshers] Trimmed cell and embedded refinement mesh conversion issues | michele | OpenFOAM Meshing & Mesh Conversion | 2 | July 15, 2005 04:15 |
Nusselt Number of the order of 35000 | chinmay | FLUENT | 4 | May 31, 2001 03:06 |
