March 26, 2012, 03:13 |
Radiation modelling help
Rep Power: 14 |
Hi everyone,
I have a heat sink with straight fins and a heat source at the center of the base plate.(from a conference paper experimental study) It is forced convection + radiation problem. Since i have never been using radiation, i require some help in setting up the case. I have the dimensions, inlet velocity and heat input details. In addition the paper says the heat sink has an emissivity of minimum 0.8 which was done by black sulfuric acid anodizing. how do i incorporate this in my model? pl do help asap. Thanks |
March 26, 2012, 04:54 |
Rep Power: 143 |
Have a look at the CFX radiation models. I strongly recommend you do a test case (radiative heat transfer between two plates where an analytical solution exists) so you can get radiation modelling workign before you apply it to a larger simulation.
heat radiation modelling | chubb | STAR-CCM+ | 5 | March 20, 2010 17:39 |
Radiation modelling Surface-to-Surface V11 | TobiasZ | CFX | 1 | December 18, 2007 08:47 |
Radiation modelling | Deeps | CFX | 2 | September 7, 2007 10:12 |
solar radiation modelling | PONDA | FLUENT | 0 | April 6, 2007 03:51 |
Questions about radiation modelling | Yingchun | CFX | 5 | November 23, 2005 01:53 |
