-   -   the calculation of gradient (http://www.cfd-online.com/Forums/cfx/99078-calculation-gradient.html)
zakir hussain March 26, 2012 00:45
hello everybody
From 10.1.1.3 Control Volume Gradients of the CFX-Sover Theory Guide ,I know that:
\nabla(\varphi)=\frac{1}{V}*\sum(\varphi\Deltan)_{ip}
where\Deltan is the outward surface vector at ip,V is the volume of the control volume.
We can use the utility name USER_GETVAR to obtain the gradient we interest.what I want to know is how it calculate the gradient.What kind of algorithm does it use?Is it as the formulation above?
I have a source term like this:
source=-\frac{1}{V}\sum(\varphi_{f}A_{f})
where\varphi_{f} is the value of the variable at the cell faces f, and A_{f} is the face area vectors
How can I implement it with fortran or something else?
Thank you very much!
zakir
zakir hussain March 31, 2012 23:34
hello everyone
I hope I can get help from you.
zakir
ghorrocks April 1, 2012 06:53
What is the sum over? All the faces of the conttrol volume?
What is the purpose of the source term? I cannot see its physical significance.
zakir hussain April 2, 2012 09:33
yes,the sum over represents all the faces of the control volume.Considering the conservation I should solve the divergence of phi what I use as an source term of poisson equation through Gauss's law ,like
\nabla\cdot\varphi=\frac{1}{V}\sum(\varphi_{f}A_{f})
Thank you for your help!
zakir
