[Sponsors] | |||||
Rep Power: 3 ![]() |
Is there a way to extract mesh co-ordinates for a mesh created in Ansys workbench ? I need to use the co-ordinates of the node points for other applications.
Max
One way to do that is to use the export function:
File -> export -> export... and then select the variables X,Y,Z |
Ya simply exporting the mesh data in .poly format and reading on notepad works.
Instead of setting boundary conditions for surfaces as a whole, I need to set temperature for individual nodes. Is thr a way ? I have extracted the x,y,z co-ordinates of all the nodes.
Max
You can use a user function in CFX. You enter the temperature value at certain points and CFX interpolates the values in between. You can even import the data from your .csv file.
| Thread Tools | |
| Display Modes | |
| Thread | Thread Starter | Forum | Replies | Last Post |
| how to set periodic boundary conditions | Ganesh | FLUENT | 12 | April 10, 2013 00:44 |
| Mesh motion with Translation & Rotation | Doginal | CFX | 0 | August 3, 2011 16:37 |
| Interpolating volume data onto quad surface mesh | N.R. | CFX | 6 | June 7, 2007 08:15 |
| Icemcfd 11: Loss of mesh from surface mesh option? | Joe | CFX | 2 | March 26, 2007 18:10 |
| Gambit problems | Althea | FLUENT | 21 | February 6, 2001 07:05 |
