January 11, 2015, 21:58 |
Conservative interface flux
Nurzhan
Rep Power: 12 |
Hello!
I am using the domain interface to connect two solid domains. I chose the conservative interface flux and set thermal contact resistance to zero. Will it be right to say, that at the interface heat is described as follows: (the left side of the equation represents the first solid, and the right side represents the second), if heat conducts in X direction? Any help is appreciated. Regards, Nurzhan |
January 12, 2015, 09:29 |
Rep Power: 32 |
At the interface the heat flux normal to the interface is conserved; therefore, you must project the heat flux vector along the normal direction.
January 12, 2015, 14:02 |
Nurzhan
Rep Power: 12 |
Applying heat flux at mesh/wall interface for a solid-fluid heat transfer? | nit4tin | FLUENT | 6 | August 19, 2018 14:50 |
Waterwheel shaped turbine inside a pipe simulation problem | mshahed91 | CFX | 3 | January 10, 2015 11:19 |
Frozen Rotor 1:1 Mesh Connection | pharley | CFX | 5 | January 31, 2013 16:15 |
how to apply heat flux at fluid solid interface | nvm2011 | CFX | 6 | April 18, 2012 05:22 |
Flux Calculation between moving interface. | Apurva Shukla | Main CFD Forum | 0 | August 17, 1999 03:56 |
