-   -   A problem of simulation using ICEM CFD Replay Remeshing (http://www.cfd-online.com/Forums/cfx/99480-problem-simulation-using-icem-cfd-replay-remeshing.html)
fluid vertical turbine April 4, 2012 07:46
2 Attachment(s)
I try to use the icem CFD Replay Remeshing to simulate this case: the vertical is vabrate when it is rotating. the model is as following:
model.gif[/IMG]
it composed by four part:the vertical part,the vebrating part,the up and down static part.
then now I do it as tutorials step by step,I creat the files: .tip and .rpl
but when a cfx-solver run to remshing,the icem start automatic and it get the fault.it said as: wrong.gif[/IMG]
can give any advice about what's the cause of this probleam,and how to fix it (I use ansys 13.0,is it the problem of istalltion). thank you very much.
the other probleam is how to prview the motion of mesh(to check the motion of mesh is right or not) .
thank you !
