April 16, 2012, 11:29 |
Varying time-step and Results freequency
Jamie
I have a CFX simulation that is basically a pipe with inlet and outlet orifice's. the simulation runs over 4.5ms, with a time step of 0.1ms. I now need to run the same simulation but with inlet events before this to try and replicate initial conditions. This brings the whole simulation to 1050ms (1.05s), but I only need the results from the last 4.5ms as before.
I have it all set up but running it now would give me 10500 time steps and take 600+ hours and 240GB results. The accuracy of the first 700ms is not so important so ideally I want a time-step of 10ms for the first 700ms, then change to a 0.1ms time-step after this. Is this possible and if so, how? I would also like to only record the results near the end. I have tried setting trn results to, Time Interval: t>0.99[s], but this gives me a resolves to dimensionless error. Any ideas on this? Cheers |
April 17, 2012, 02:00 |
Rep Power: 143 |
Why do you use 0.1ms time steps? Have you confirmed these are adequate?
I would run the whole thing using adaptive timesteps, adapting to 3-5 coeff loops per iteration. This means you will be running a sufficiently small time step at all times, and the time step will automatically get bigger when it can and smaller when it needs to. |
Extrusion with OpenFoam problem No. Iterations 0 | Lord Kelvin | OpenFOAM Running, Solving & CFD | 8 | March 28, 2016 11:08 |
Superlinear speedup in OpenFOAM 13 | msrinath80 | OpenFOAM Running, Solving & CFD | 18 | March 3, 2015 05:36 |
Moving mesh | Niklas Wikstrom (Wikstrom) | OpenFOAM Running, Solving & CFD | 122 | June 15, 2014 06:20 |
Orifice Plate with a fully developed flow - Problems with convergence | jonmec | OpenFOAM Running, Solving & CFD | 3 | July 28, 2011 05:24 |
DPM UDF particle position using the macro P_POS(p)[i] | dm2747 | FLUENT | 0 | April 17, 2009 01:29 |
