how to apply heat flux at fluid solid interface
Old   April 16, 2012, 22:58
Default how to apply heat flux at fluid solid interface
Mustard
nvm2011 is on a distinguished road
hello,everyone,i am doing a heat transfer simulating, a heat flux is regarded as heat source,but its location is at the interface of air and steel,how can i apply it correctly?i used to apply it at the boundary of solid wall(steel),but the result seems to be wrong beacause there is no heat flux toward the air.
nvm2011 is offline   Reply With Quote
Old   April 17, 2012, 01:57
Make the steel/air boundary an interface, and apply a heat flux to the air side of the interface.
Old   April 17, 2012, 10:23
stumpy is on a distinguished road
... as a boundary source term on the Sources tab for the interface boundary condition.
stumpy is offline   Reply With Quote
Old   April 17, 2012, 21:01
Mustard
I've applied a heat flux to either the air side or the steel side of the interface,but both results gave high temperature that were obviously incorrect according the my experiment.
Old   April 17, 2012, 21:12
Mustard
I made the heat flux as boundary source in the simulation,and the result temperature met the experiment data well,but the heat flux calculated by the function calculator(with areaInt) in CFx-Post was far more less than the value I gave in the boundary source,I am very confused about this,could you please explain it?I am new to heat transfer analysis and looking forward to your kind help.
Old   April 18, 2012, 05:04
唐磊
tanglei is on a distinguished road
hi
i wonder why the heat flux must be at the interface of air and steel?
and do you mean that you are going to make the heat flux toward both the air and the steal?
tanglei is offline   Reply With Quote
Old   April 18, 2012, 05:22
Mustard
Originally Posted by tanglei View Post
hi
hi,tanglei
In my experiment,I make a band that generating heat stuck to the interface steel/air interface,could you tell me how to apply this heat load to the model?I've done the simulation many times without any reasonable result.
Constant velocity of the material Sas CFX 15 July 13, 2010 08:56
No results for solid domain Gary Holland CFX 10 March 13, 2009 03:30
urgent: heat transfer fluid to solid marco FLUENT 1 October 28, 2005 22:17
heat transfering between solid and fluid Benny FLUENT 4 November 15, 2004 19:20
Terrible Mistake In Fluid Dynamics History Abhi Main CFD Forum 12 July 8, 2002 09:11
