Home > Forums > Mesh Generation & Pre-Processing Software > enGrid
stl geometries are never good enough - why?
Like Tree1Likes
  • 1 Post By ogloth
Old   April 5, 2013, 10:00
Default stl geometries are never good enough - why?
Klaus
klausb will become famous soon enough
after completing the damper tutorial, I am trying to create an alternative mesh for an OpenFoam tutorial using enGrid.
When I try to import a stl geometry, I get the error message:
p, li { white-space: pre-wrap; } "The STL geometry could not be cleaned"
The same happened with an airfoil.stl I created.
What are the required settings?
Klaus
klausb is offline   Reply With Quote
Old   April 5, 2013, 12:33
Oliver Gloth
ogloth is on a distinguished road
STL is an awful format and most CAD programs fail to export water-tight STL files. Open-Cascade based software generally does a good job of this. Alternatively you can fix the geometry using Blender.
Feel free to post a geometry which fails and I'll have a look at night -- not before Monday, unfortunately.
Engrid badly needs an import function for CAD files without the detour via STL or any other mesh based format.
Regards,
Oliver
ogloth is offline   Reply With Quote
Old   April 5, 2013, 13:12
Default S809 airfoil.stl needed
Klaus
the stl file is too large to post.
What I need is a stl file of the S809 airfoil with a span twice the chord. Find the coordinate file for the S809 airfoil attached.
Airfoil coordinate files describe the geometry for a chord of 1 which will be interpreted for my simulation as 1m so the span should be 2 (2m).
If the program can't handle coordinates ranging from 0 to 1, they can be multiplied by e.g. 100 or 1000. A correction factor can easily be set in OpenFoam.
How can such an stl be created?
Do you have plans to enable step or iges imports?
Klaus
Old   April 8, 2013, 09:20
Oliver Gloth
Hi Klaus,
I just had a look at your airfoil and it imports after changing the format slightly to match the Selig airfoil format. It can then be exported to Blender and within Blender a proper volume can be created with little effort.
Do you want your wing between two walls (symmetry planes), or do you want a proper wing tip?
I'll send you a file which you can import into enGrid later today or tomorrow, because there is loads of other work to do ...
Cheers,
Oliver
Old   April 8, 2013, 17:39
Default The S809 test case
Klaus
my intention is to use enGrid to create the mesh for the S809 3D test case described in the ris-r-1581.pdf paper.
Paper download: http://http://www.findthatpdf.com/se...r-1581.pdf.htm
Klaus
Old   April 9, 2013, 03:12
Oliver Gloth
here is the promised file. It is in the enGrid <-> Blender exchange format which can be directly imported into enGrid. Boundary codes have already been defined. Please note that the wing is split into an upper and lower part; this is important to keep the sharp trailing edge intact.
Cheers,
Oliver
juaneco2710 likes this.
Old   November 28, 2013, 18:37
Roberto Pieri
robyTKD is on a distinguished road
Hallo Oliver,
I am very much interested in building a mesh using Blender + enGrid.
I have downloaded the file you attached in previous post (it is great!!). I would like to know how did you build the .becg file (from the definition of the airfoil curve to the definition of boundaries).
Is it possible to have any advice? or do you know where I can find a little guide?
Thank you very much for the attention!
Cheers,
Roberto
robyTKD is offline   Reply With Quote
Old   November 29, 2013, 16:40
Retired Super Moderator
Bruno Santos
Greetings to all!
@Roberto: I'm not certain how Oliver did it, but the following tutorials come to mind:
And enGrid's wiki is open to public contributions, so please do contribute if you can: https://github.com/enGits/engrid/wik...nGrid%27s-wiki
Last but not least, do keep in mind that Oliver can provide faster support if you use the very accessible and helpful support line at http://engits.eu/en/support !
Best regards,
Bruno
Old   December 1, 2013, 15:10
Roberto Pieri
Thank you for the quick reply Bruno.
I followed the tutorials that you proposed above, unfortunately I am not able to obtain something like the file made by Oliver. In particular I met difficulties in extruding the airfoil profile (producing a good .stl) and creating symmetry planes with holes in correspondence of the airfoil in Blender.
However I'll ask for help on the enGits forum as you proposed!!
I would be pleased to contribute to the enGrid's wiki!
Cheers,
Roberto
How to generate STL files for idealized geometries? werder85 Main CFD Forum 0 November 1, 2012 12:47
Defining boundary conditions STL file marco100 OpenFOAM Pre-Processing 7 May 23, 2012 08:06
How to do a good geometry clean-up in GAMBIT mahadevan.swamy Main CFD Forum 0 June 19, 2009 21:13
BC for complex geometries benru OpenFOAM Pre-Processing 3 August 10, 2007 09:43
[blockMesh] Is blockMesh generally considered a good quality tool york OpenFOAM Meshing & Mesh Conversion 4 November 15, 2006 13:42
