March 14, 2014, 04:37 |
Ensight grid creation
Rep Power: 12 |
Hi, I am a new Ensight user, and I am attempting to create an image showing the time-averaged velocities (using vector arrows) of particles in my system (a rotating cylinder). I want to create a 100x100 grid centred on this cylinder, so that I am able to perform calculations in each section of the grid. Can anyone point me in the right direction as to how to split my rotating cylinder Part into the desired subsections?
Thanks Kelly |
March 15, 2014, 13:55 |
Grid Clip
Kevin Colburn
Kelly,
If you are looking to display the velocity vectors from your continuum on a a uniform grid, you can simply use the Clip Plane Creation, Along with the Plane Tool. With the Plane Tool, you can either use the resolution of the mesh, or specify a "Grid" clip, where you can specify the X and Y resolution in a uniform fashion. This will intersect the domain with a regular grid, on which you can display vector arrows (typically at each node of the grid). If you have further questions, please do not hesitate to contact your local EnSight Support representative in your region, or via the main help line (support@ensight.com). -Kevin
Kevin Colburn Computational Engineering International, Inc. www.ceisoftware.com kevin@ensight.com |
March 18, 2014, 05:42 |
Rep Power: 12 |
Hi Kevin, Thanks so much for your response. I am actually looking to make a 3d grid, with x, y and z components, where I can extract information from each grid element and get averages.. I will try contacting my Ensight rep as well. Cheers
O grid creation failed | dhxlxz | ANSYS Meshing & Geometry | 2 | December 10, 2009 22:05 |
[ICEM] Double Y grid and single Y grid | brissyben | ANSYS Meshing & Geometry | 5 | July 27, 2009 10:24 |
Grid refinement. | Sas | Main CFD Forum | 8 | September 2, 2005 09:36 |
GRID TO GRID INTERPOLATION in FLUENT | calogero | FLUENT | 3 | June 4, 2003 09:32 |
Numerical methods for discontinuous grid interfaces? | Hansong Hang | Main CFD Forum | 12 | September 16, 1998 23:26 |
