Home > Forums > EnSight
Point part probing
Old   July 29, 2014, 07:59
Default Point part probing
gaetan Hamel
g.hamel is on a distinguished road
I tried to create a list of points using the Point parts tool.
Now what I want to do is to use them as probes.
The user manual tells that this is the purpose of this tool but I can't figure out how to use those points as probes.
Could you give me some help.
Regards,
Gaetan
g.hamel is offline   Reply With Quote
Old   August 19, 2014, 04:52
gaetan Hamel
I contacted the customer support and found a solution.
What you have to do is :
  • Use ElemToNode to pass the variables to the nodes
  • Then create>point parts with the part containing the variables
  • File > Export > Geometric entities > Flatfile with the corresponding part
You will get a data file containing the active variables at the desired coordinates.
I personally have a bug if I save more than one time step at a time, the customer support wasn't able to reproduce it though.
(Ensight 10.0.3e on Linux)
Hope this helps.
Thread Tools
Trackbacks are On
Suspected division by zero on velocity reported by point probe dahicke STAR-CCM+ 1 July 4, 2013 02:16
replacing of shock tube high pressure part with a boundary condition for low pressure immortality Main CFD Forum 0 May 2, 2013 13:30
what boundary condition is proper for simulation of shock-tube low pressure part? immortality OpenFOAM Running, Solving & CFD 0 May 2, 2013 13:22
Problem with UDF compiling for kTkLW model Wantami FLUENT 0 July 18, 2011 05:11
matching variable data with grid point data anfho OpenFOAM Programming & Development 0 May 6, 2011 15:28
